Delete accounts in bulk (soft delete) (web client)
Background / Value
After a security breach or the dissolution of a department, it makes sense to delete several accounts at the same time. Do this conveniently in the web client.
Related features
Change password options in bulk (web client)
Step-by-step process
- Click "Analysis".
- Select the category "AD users".
- Click on "All AD user accounts".
- Set options for the scenario.
- Click on "Start calculation".
- Use sorting, filtering, grouping and column selection to narrow down your selection.
- Select the desired entries.
- Click "Soft delete user account".
- You must enter a comment.
- Click "Execute Action".
The job will be transferred to the ARM server and executed there. ARM administrators can see the status in the task overview scenario.
