Basic configuration
To install a basic configuration, select the credentials used by the ARM service to request the Active Directory.
ARM requires an SQL database to store the data. In the basic configuration, specify the following:
- SQL Server Name
- SQL Server Instance
- SQL Server authentication method and credentials
Create a basic ARM configuration
- Start the Configuration application.
Click Basic Configuration.
Enter the SQL Server credentials.
See SQL Server Express and ARM for additional information.
SQL Server Express is not included in the ARM installation package. If you choose the Express installation, the ARM installer downloads and installs SQL Server 2025 Express, including the appropriate pre-configuration. Installs on the automatic path will require internet access, while a manual path allows you to point to a pre-downloaded installer for servers without internet access.
(Optional) Reclaim additional hard drive space by shrinking the database and database logs.
See SQL Server database maintenance for instructions.
