Delegate user provisioning processes to help desk personnel
ARM helps to make the user provisioning processes easy to delegate. With ARM, you can delegate all of these responsibilities to your help desk. SolarWinds recommends beginning the process by delegating simple account management. Depending on your employee qualifications, you can expand the responsibilities gradually over a period of time.
Process reports
The following table lists the processes you can delegate with ARM.
| Report type | Related procedure |
| Active Directory |
Modify group and user attributes |
| Microsoft Exchange |
Define your help desk personnel and assign resources with ARM
Using the settings in the ARM configuration application, ARM administrators can delegate their standard processes to help desk personnel by defining the help desk responsibilities and assigning the appropriate resources.
See the following sections for more information.
Assign responsibilities to help desk personnel
Using the ARM Configuration application, you can define specific responsibilities to each help desk employee. The following example describes a typical assignment of responsibilities.
See Managing ARM users for more information.
Start the Configuration application.
Click User Management.
In the User and Role Management window, click the Switch to Role Management link at the top of the window.
In the Search field, enter a search term and then click
to locate the targeted account. -
Drag the search result to the List of accounts that use ARM column.
Click the drop-down menu and assign the IT Helpdesk role to the account.
See Define Access Rights Manager user roles for details about customizing this role.
