Create and delete contacts
Background / Value
With ARM, you can documented create contacts and manage them quickly, e.g. to add them to distribution groups.
Related features
Manage distribution group memberships
Step-by-step process
- Select "Start".
- Click "Create new user or group".
Select a template to create a contact.
ARM provides a sample template for the creation of contacts. You must customize this template before you can use it. See Customize ARM templates.
ARM creates contacts using the Exchange Powershell connection. Therefore, an Exchange resource configuration including the preparation of the Exchange Powershell has to be completed.
- Specify an OU.
- Enter names and email addresses.
- You must enter a comment.
- Start the process.
- Use the search to find a contact.
- Click on the search result.
- ARM switches to the Accounts view.
- Right-click the contact.
- Select Delete account.
- ARM shows the contact to be deleted.
- ARM shows the login which is used to delete the contact. If necessary, specify other credentials.
- Start the execution.
