Documentation forAccess Rights Manager
Required accounts and permissions for a SharePoint scan
To perform a SharePoint scan, configure the process and scan accounts.
Process Account
This account is used to execute the scan process on the selected collector. This account must have local administrative rights and interactive log in privileges on the collector. SolarWinds recommends that you leave the input blank. ARM will use the service account from the base configuration.
Scan Account
This account is used for the actual scan.
SharePoint on-premise
This account must always be the same as the owner account registered for the site collection (also known as the primary site collection administrator). The corresponding user account is defined when a site collection is created and can only be viewed or changed using the SharePoint central administration.
You can access Navigate in the Central Administration at Application Management > Site Collections > Change site collection administrators > Selection of the site collection > Primary site collection administrator.
SharePoint Online
To access SharePoint Online, you can use either a registered app (recommended) or a service account.
Access SharePoint Online using a registered app
To access SharePoint Online using a registered app, follow the steps as described in the following Microsoft guide: Granting access using SharePoint App-Only (© 2022 Microsoft, https://docs.microsoft.com/en-us/sharepoint/dev/solution-guidance/security-apponly-azureacs, obtained April 5, 2022).
Use the App ID created in this way as the username and the Client Secret Value as the password for the scan account.
You can use these credentials in the SharePoint change configuration.
The Client Secret has an expiration date. By default, the account is valid for 1 year.
For more information, see the article Replace an expiring client secret in a SharePoint Add-in (© 2022 Microsoft, https://docs.microsoft.com/en-us/sharepoint/dev/sp-add-ins/replace-an-expiring-client-secret-in-a-sharepoint-add-in, obtained on September 7, 2022).
Access SharePoint Online using a service account
The scan account requires Site admin permissions, as shown below.
(Screenshots property of © 2020 Microsoft Corporation)
You can set the permissions in the SharePoint Online admin center.
Access SharePoint Online with Modern Authentication
To Access SharePoint Online with modern authentication, you must create a certificate and store it under personal in local machine certificates.
The setup includes an application ID and thumbprint, which you will use as your user name and password for the configuration of the SharePoint online scan in ARM. The certificate must be store under personal in the Local Machine Certificates (cert:\LocalMachine\My) and in root (cert:\LocalMachine\Root).
Use the PowerShell script below.
# Scripts are not supported under any SolarWinds support program or service.
# Scripts are provided AS IS without warranty of any kind. SolarWinds further
# disclaims all warranties including, without limitation, any implied warranties
# of merchantability or of fitness for a particular purpose. The risk arising
# out of the use or performance of the scripts and documentation stays with you.
# In no event shall SolarWinds or anyone else involved in the creation,
# production, or delivery of the scripts be liable for any damages whatsoever
# (including, without limitation, damages for loss of business profits, business
# interruption, loss of business information, or other pecuniary loss) arising
# out of the use of or inability to use the scripts or documentation.
# create certificate under personal
$mycert = New-SelfSignedCertificate -DnsName "domain1.local" -CertStoreLocation "cert:\LocalMachine\My" -NotAfter (Get-Date).AddYears(100)
-KeySpec KeyExchange
# export certificate to .cer file to upload to azure
$mycert | Export-Certificate -FilePath c:\temp\SpoCert.cer
# Export certificate to .pfx file to install the certificate on other machines
$mycert | Export-PfxCertificate -FilePath c:\temp\SpoCert.pfx -Password (Get-Credential).password
# install certificate for root
Import-Certificate -FilePath c:\temp\SpoCert.cer -CertStoreLocation cert:\LocalMachine\Root
