Add OneDrive resources
Before you begin, set up access in the Azure portal so you can configure a OneDrive scan.
Start the Configuration application.
Click Scans.
Click OneDrive.
In the Process Credentials window, select the credentials for the Process account, and then click Apply.
SolarWinds recommends leaving the input blank. ARM will use the service account from the base configuration.
The account will not be used to scan the OneDrive permissions. You will set up this account in a future step -
In the OneDrive selection window, click link next to Credentials.
Enter the credentials that you created when you prepared the Microsoft/Office 365 integration on the Azure portal, and then click Apply.
In the App-ID field, enter the application ID as the user name.
In the Client Secret field, enter the client secret as the password.
In the Tenant field, enter the online domain.
In the OneDrive selection window, select the resources, and then click Apply.
In the Name field, select the checkbox to activate the required resource.
Under Assigned collectors, select one or more collectors that are configured with an Internet connection.
