Organizational help for administrators
Besides automated documentation and reports ARM also includes a number of additional documentation features. These allow you to add post-its to objects manually or give AD groups aliases with the "purpose groups" feature.
Add notes to user accounts and groups
Background / Value
Flag user and group accounts with post-its. This allows you to add tasks directly to individual objects.
Step-by-step process
Right-click on an account and select "Add note" from the context menu.
- Add a note.
- Click "Add".
- Select "Start".
- Click "Notes".
The list shows all notes. With a right click on the note, you can trigger a number of different functions.
Purpose Groups: Give aliases to groups
Background / Value
Purpose groups add clear descriptions to AD groups. Often these groups have very technical names and so it is difficult for users or administrators to tell what the purpose of an AD group is. Adding aliases makes the picture much clearer.
The alias descriptions are only visible in the ARM views and reports. There are no changes to Active Directory attributes.
Create a purpose group
Right-click on an AD group. Select "Create Purpose Group" from the context menu.
- Give the AD group an alias and add a description for the group.
- Click on "Create".
Delete or modify a purpose group
- Select "Resources".
- Expand "Purpose Groups".
- Select the desired purpose group by right-clicking on it.
- Select "Delete Purpose Group" or "Modify Purpose Group" from the context menu.
The removal process only affects the purpose group, the added alias in ARM. No changes are made to Active Directory.
