Manage alerts
You can modify saved alert configuration in the ARM home page.
                                    Open the ARM home page.
                                    In the toolbar, click Start.
                                    Under Security Monitoring, click Manage alerts.   The Manage Alert windows displays all alert configurations.
                                    In the Filter field, search for an alert.
                                    Turn the targeted alerts on or off.
                                    Use the links to edit, delete, enable, or disable the selected alert configuration. You can also right-click an entry and use the context menu.
                                    When you are finished, click Close.
