Documentation forServer & Application Monitor
Sybase SQL Anywhere
This template assesses the performance of the server database by retrieving performance data from the monitoring tables.
Prerequisites
Sybase SQL Anywhere Administrative Tools must be installed on the SolarWinds Platform server, (Administrative Tools can be found on installation media during installation process).
Credentials
Database user name and password with DBA authorities.
Before using this template you should put correct database name (DBN property) in Connection String.
Example: Driver={SQL Anywhere 12};DBN=demo;Host=${IP};Uid=${USER};Pwd=${PASSWORD};
Component monitors
Click here for an overview about SAM application monitor templates and component monitors. SAM API Poller templates are also available.
Components without predetermined threshold values provide guidance such as "Use the lowest threshold possible" or "Use the highest threshold possible" to help you find a threshold appropriate for your application.
CPU usage (s)
This monitor returns the CPU usage for the database server process. Values are in seconds. The value returned for this property is cumulative since the database server was started.
Current Cache Size (kB)
This monitor returns the current cache size, in kilobytes.
Main Heap Pages
This monitor returns the number of pages used for global server data structures.
Pinned Cache Pages
This monitor returns the number of pinned cache pages.
Dirty Cache Pages
This monitor returns the number of cache pages that are dirty (needing a write).
Replaced Pages in Cache
This monitor returns the number of pages in the cache that were replaced.
Disk Reads
This monitor returns the number of disk reads.
By default, this monitor has the Count statistic as difference box checked. It will only show the new statistic since the last polling period.
Free Space in System Dbspace (MB)
This monitor returns the amount of free disk space for System dbspace in MB.
Free Space in Translog Dbspace (MB)
This monitor returns the amount of free disk space for Translog dbspace in MB.
Free Space in Temporary Dbspace (MB)
Current Connetions
This monitor returns count of the number of licensed connections in use.
Unique Connections
This monitor returns the number of unique client network addresses connected to a network database server.
Open HTTP Connections
This monitor returns the number of HTTP connections that are currently open within the database server. They may be actively processing a request or waiting in a queue of long lived (keep-alive) connections.
Actively Processing HTTP Connections
This monitor returns the number of HTTP connections that are actively processing an HTTP request. An HTTP connection that has sent its response is not included.
Open HTTPS Connections
This monitor returns the number of HTTPS connections that are currently open within the database server. They may be actively processing a request or waiting in a queue of long lived (keep-alive) connections.
Actively Processing HTTPS Connections
This monitor returns the number of secure HTTPS connections that are actively processing an HTTPS request. An HTTPS connection that has sent its response is not included.
Requests in Queue
This monitor returns the number of requests that are currently queued up waiting for an available server thread. Returned value should be less than 5.
Bytes Received
This monitor returns the number of bytes received during client/server communications. This value is updated for HTTP and HTTPS connections.
Bytes Sent
This monitor returns the number of bytes sent during client/server communications. This value is updated for HTTP and HTTPS connections.
Optimized Queries
This monitor returns the number of requests fully optimized.
Reused Queries
This monitor returns the number of reused query plans.
Bypassed Queries
This monitor returns the number of requests reused from the plan cache.
Cache Hits
This monitor returns the number of database page lookups satisfied by finding the page in the cache.
File Reads
This monitor returns the current number of file reads those were issued by the server, but haven't yet completed.
File Writes
This monitor returns the current number of file writes those were issued by the server, but haven't yet completed.
Pages Read from Disk
This monitor returns the number of pages that were read from disk.
Pages Written to Disk
This monitor returns the number of modified pages that were written to disk.
Free Pages in System Dbspace
This monitor returns the number of free pages in the system dbspace. The FreePages property is only supported on databases created with version 8.0.0 or later.
Locks
This monitor returns the number of locks held by the database.
