Documentation forServer & Application Monitor
Use filters for AppStack
You can filter AppStack data by status, display name, and applications to create different layouts for data to speed troubleshooting for servers and virtual servers.
You may need to log in with an administrator account to perform this action.
Filter options
By default, every object displays in the AppStack Environment view. To display only objects with a certain status, filter the view by selecting one or more statuses and then applying the filter. You can also filter objects based on various properties, as well as keywords.
The filtering sidebar includes the following options:
Statuses only become available for filtering when an object in your environment is in that state. For example, if no objects have a status of Down, the Down status will not be available when filtering.
Creating filters
Creating filters using the AppStack filter properties provides more options to refine the content displayed in the AppStack.
  1. Click My Dashboards > Environment, and then click [+] Add Filter Properties.
  2. In the pop-up menu, select one or more objects from the Orion Object drop down list.
  3. Click Add column to display the new filters.
