Documentation forServer & Application Monitor
How the Application Dependencies feature in SAM works
Depending on how the Application Dependencies feature is configured for your environment, SAM can use two types of polling to collect data:
  • Application Dependency polling discovers and monitors the following types of connections:
    • Application to application, in a typical client/server process monitored by SAM
    • Application to server, with a server process not currently monitored by SAM
    • Server to application, with a client application process not monitored by SAM
  • Connection Quality polling tracks TCP communication traveling from servers that host applications to target servers. This synthetic polling collects latency and packet loss statistics for connections without intercepting network traffic, also known as "packet sniffing."
SAM uses SolarWinds Platform agents to monitor application dependencies
To monitor application dependencies, SAM uses SolarWinds Platform agents to flag nodes, which represent physical or virtual servers. An agent must exist on at least one of the two nodes for which you want to display dependencies.
You can deploy agents by adding at least one application monitor to each node you want to monitor, as described in Configure Application Dependencies settings in SAM. If a node does not host an agent, the Application Connections widget displays sample data on the Node Details page.
Agent plugin overview
To support the Application Dependencies feature, SAM deploys agent plugins to nodes to monitor connections and network communications. Plugins gather data from any Additional Polling Engines to send to the Main Polling Engine.
Enable "Allow automatic agent updates" on the Manage Agents > Edit Agent Settings page so you don't have to update plugins manually.
For Application Dependency polling:
  • SAM deploys agent plugins to nodes if Application Dependency polling detects application-to-application or application-to-node connections.
  • Agent plugins collect data about dependencies between applications (application-to-application connections) and/or nodes (application-to-node connections). It is available in Linux x64, Linux x86, and Windows versions.
    To avoid performance issues, SAM does not deploy Application Dependencies plugins to the Main Polling Engine, which is usually the SolarWinds Platform server.
For Connection Quality polling, if enabled:
  • SAM deploys additional agent plugins to collect TCP latency and packet loss metrics.
  • For Windows nodes connected to clients that host applications and application processes, TCP agent plugins include an Npcap driver to support Nping.
    If you disable Connection Quality polling, note that SAM removes the TCP agent plugin but not the Npcap driver. If you need to remove the driver, see this article.
SAM relies on server-initiated communications to detect "from” or to" nodes, also called “passive agents” or “agentless" nodes. Only one node in a pair requires an agent plugin. However, note that data gathered by polling depends on communication settings for both nodes, as described here:
  • If target and client nodes both host agent plugins, SAM collects data via Application Dependency and Connection Quality polling for both nodes.
  • If only the target node has an agent plugin, SAM collects IP address and port data for the client node but not application details, process names, or connection statistics.
  • If only the client node has an agent plugin, SAM collects IP address and port data for the server node. If Connection Quality polling is enabled and SAM deployed a TCP agent plugin to the connection source node, polling can capture latency and packet loss statistics.
Use the Manage Agents page to check the status of agent plugins.
