Process Monitors for Windows
As described here, SAM includes several "component monitor types" that use various methods to focus on elements such as services, logs, or processes. Process Monitors for Windows test if a specified Windows process is running, and reports the CPU, virtual memory, and physical memory used by all instances of the process.
For a Linux version, see Process Monitor (SNMP).
One example of a Process Monitor is the Worker Process Statistics Monitor included in the AppInsight for IIS template . This component monitor collects data and status about the worker process activation service for an application pool.
Note the following details that apply to most Process Monitors for Windows:
- They support WinRM, WMI, the SolarWinds Platform Agent for Windows, ICMP, and External Node polling methods.
- They do not compute a statistic.
- Five seconds after a sample is retrieved from the Win32_PerfRawData_PerfProc_Process class (PercentProcessorTime and TimeStamp_Sys100NS properties), a second sample is retrieved; the monitor uses both samples to calculate CPU usage.
- For Process Monitors for Windows, SAM supports the use of Group Managed Service Accounts (gMSA) to enhance security and simplify credential management for monitoring services. See Use gMSA accounts for Windows polling for steps to configure gMSA.
For tips on tracking multiple processes across different servers for an application, see the Monitoring processes using SAM post in THWACK.
Field descriptions
If you create a Process Monitor for Windows in the Component Monitor Wizard, you'll be prompted to provide several values, as described next.
Description
A default description of the monitor. To override the default description, add to or replace existing text. Changes are automatically saved. The variable to access this field is ${UserDescription}.
Customize descriptions to specify what will be monitored so related alerts and notifications are more meaningful later.
Enable Component
Determines if the component is enabled. Disabling the component leaves it in the application in a deactivated state that does not influence application availability or status, as displayed in the SolarWinds Platform Web Console.
Credential for Monitoring
Select a Windows credential with WMI rights on the target node. This is typically a Windows administrator-level credential.
Click a credential in the list, or use the <Inherit credential from node> option. If the credential you need is not in the credentials list, add it in the SAM Credentials Library.
Fetching Method
Configure how SAM gathers data from target systems.
- WMI (WinRM/DCOM): Use WinRM, with DCOM as a fallback method. See Use WinRM for application monitor polling in SAM.
- RPC (Remote Procedure Call): Use RPC communication.
WinRM Authentication Mechanism
If SAM WinRM is enabled for application polling on the SolarWinds Platform server and target nodes, select an authentication method for the connection. The default setting is Negotiate.
- Default: Specifies the transport to use for WS-Management protocol requests and responses: HTTP or HTTPS. The default is HTTP.
- Digest: User name and password are required. The client sends a request with authentication data to an authenticating server, usually a domain controller. If the client is authenticated, then the server receives a Digest session key to authenticate subsequent requests from the client.
- Negotiate: The client sends a request to the server to determine the protocol to use for Simple and Protected Negotiation (SPNEGO) authentication, which can be either:
- Kerberos for domain accounts, or
- NTLM for local computer accounts
- Basic: User name and password are required, as sent via HTTP or HTTPS in a domain or workgroup.
- Kerberos: User name and password are required for mutual authentication between the client and server, using encrypted keys. The client account must be a domain account in the same domain as the server. When a client uses default credentials, Kerberos is the authentication method if the connection string is not one of the following: localhost, 127.0.0.1, or [::1].
- NtlmDomain: User name and password are required for NTLM authentication. The client proves its identity by sending a user name, password, and domain name.
- CredSssp: User name and password are optional. The Credential Security Support Provider (CredSSP) lets an application delegate the user credentials from the client to the target server for remote authentication. The client is authenticated over the encrypted channel by using the SPNEGO protocol with either Kerberos or NTLM.
Term excerpts taken from the WinRM Glossary.
Command Line Filter
Use this optional field to select which instances of a process you want to monitor, based on the command line arguments of the process. This is a text match and partial matches are also valid.
For example, to monitor only instances launched with –myOption=NorthAmerica, use –myOption=NorthAmerica. To monitor any instances launched with America in any argument, use America
See also Monitor an application process launched from a specific path in the SolarWinds Success Center.
Process Name
Specify the process name to monitor. If you do not know the process name, SAM can help you find processes to monitor.
CPU Threshold
Set thresholds based on the percentage of CPU resources used by the monitored process. When the CPU usage polls within the thresholds, the monitor switches to a Warning or Critical state. See Application Monitor Thresholds.
Physical Memory Threshold
Set thresholds based on the amount of physical memory in use by the monitored process. When the physical memory usage polls within the thresholds, the monitor switches to a Warning or Critical state.
Virtual Memory Threshold
Set thresholds based on the amount of virtual memory in use by the monitored process. When the virtual memory usage polls within the thresholds, the monitor switches to a Warning or Critical state.
IO Read Operations/Sec Threshold
Set thresholds based on the amount of I/O read operations performed per second in use by the monitored process. When the read operations poll within the thresholds, the monitor switches to a Warning or Critical state.
IO Write Operations/Sec Threshold
Set thresholds based on the amount of I/O write operations performed per second in use by the monitored process. When the write operations poll within the thresholds, the monitor switches to a Warning or Critical state.
IO Total Operations/Sec Threshold
Set thresholds based on the amount of total I/O operations performed per second in use by the monitored process. When the total operations poll within the thresholds, the monitor switches to a Warning or Critical state.
User Notes
Add notes for easy reference. You can access this field by using the variable, ${UserNotes}.
