View node and application data in SAM tooltips
You can hover over objects such as nodes and groups to view additional details in overlays called tooltips. These tooltips also include SAM-specific data, providing at-a-glance updates for quick responses. Click an object to open its Details page that shows more data, along with alert and management options.
Node tooltips
| Tooltip data | Details |
Node Status |
Current status of the node (for example, Up, Down, Unknown, or Warning). You can adjust node status settings. See Calculate node status in the SolarWinds Platform. |
Polling IP Address |
The IP address currently assigned to the node. |
Machine Type |
The vendor icon and vendor description of the node. |
Average Response Time |
The measured average response time of selected node, as of the last node poll. |
Packet Loss |
The percent of all transmitted packets lost by the node, as of the last node poll. |
CPU Load |
The percent of available processing capacity that is currently used, as of the last node poll. |
Memory Used |
The percent of available memory that is currently used, as of the last node poll. |
# of Running VMs |
Number of running VMs and total VMs. |
ESX Host Status |
Status of the ESX Host. |
Application tooltips
App Name |
The name of the application |
App Status |
The status of the application: up, down, unknown, warning, or critical |
Server Status |
Operational status of the server: up, down, warning, unplugged, or unmanaged |
Components with problems |
List of the components with problems and their statuses |
