Documentation forServer & Application Monitor
AppInsight for Exchange requirements and permissions
Exchange hybrid versions are not supported. Additionally, Group Managed Service Accounts (gMSAs) are not supported in Microsoft Exchange or Windows Scheduled Tasks Monitor (WSTM).
AppInsight for Exchange works only with the Mailbox Role, which is used for data storage. All other Exchange servers running different roles should use the Exchange application monitor templates included with SAM if you intend to monitor them. Data is collected at the same default five-minute polling interval as traditional application monitor templates.
Supported Microsoft Exchange Server versions
  • Microsoft Exchange Server 2010
  • Microsoft Exchange Server 2013
  • Microsoft Exchange Server 2016
  • Microsoft Exchange Server 2019
AppInsight for Exchange permissions
The following permissions are required to modify Exchange and WinRM settings on target servers, as well as poll performance counters:
  • Local administrator permissions are needed for automatic configuration of the exchange account, but they are not needed for monitoring after configuration is complete. However, remember Full Control permissions are necessary for PowerShell to facilitate the monitoring. For additional details, see Setting PowerShell Permissions.
  • To provide organization-wide capability, the service account (Domain User) must be a member of the View-Only Organization Management group. Membership to this group gives the User object read-only access to the entire Exchange environment, without providing any domain or local access on the Exchange server. It also prevents unauthorized access to the account.
  • To gather data, the User object must be assigned the Mailbox Search management role within Exchange.
    This role is only required to modify Exchange and WinRM settings on server. It's not necessary for standard polling.
  • For Mailbox statistics, Hub Transport Servers need to be accessed via RPC.
PowerShell requirements
Common configuration issues
