IMAP4 monitor
This SAM component monitor tests the ability of an IMAP4 server to accept incoming connections and respond with the correct code.
Statistic
This component monitor does not compute a statistic.
Field descriptions
Description
A default description of the monitor. To override the default description, add to or replace existing text. Changes are automatically saved. The variable to access this field is ${UserDescription}.
Customize descriptions to specify what will be monitored so related alerts and notifications are more meaningful later.
Enable Component
Determines whether the component is enabled. Disabling the component leaves it in the application in a deactivated state not influencing either SolarWinds SAM application availability or status.
Port Number
Specify the port number used for IMAP4 sessions. The default value is 143.
Response Time Threshold
Set the warning or critical threshold conditions based on the response time. The response time is the time in milliseconds it takes SolarWinds SAM to determine that a component is not Down and to retrieve any statistical data. See Application Monitor Thresholds.
User Notes
Add notes for easy reference. You can access this field by using the variable, ${UserNotes}.
