HTTPS Monitor
This SAM application monitor template tests a web server's ability to accept incoming sessions over a secure channel and then transmit the requested page.
Credentials
Administrator on target server.
This template includes a single component monitor that tests a web server's ability to accept incoming sessions over a secure channel and then transmit the requested page. The component monitor can also test the security certificate and you can configure how certificate errors are handled. Click here for details.
Provide a valid URL and Port Number. By default, the SAM variables contained in the default value for the Url field attempt to monitor a website at the IP address of the assigned node ${IP}, via the specified port ${PORT}.
The default port is 443. If using a proxy, specify proxy details for this component monitor.
