Web Link Monitor
This SAM component monitor collects the number of broken or invalid links on a web page. It is included in the Web Link application monitor template that you can assign to individual nodes.
Statistic
The number of broken or invalid links collected.
Field descriptions
Description
The default description of the monitor. If you override the default description, changes are saved automatically. The variable to access this field is ${UserDescription}.
Enable Component
Determines whether the component is enabled. Disabling the component leaves it in the application in a deactivated state not influencing either SolarWinds SAM application availability or status.
Credential for Monitoring
Select a credential that can access the password-protected portion of the web site. Click a credential in the list, or use the <Inherit credential from node> option. If the credential you need is not in the credentials list, add it in the Credentials Library. See Understand the Credentials Library for details.
Url
Specify the URL you want to monitor. The ${IP} variable contained in the default value for this field attempts to monitor a website at the IP address of the assigned node.
Accept Compression
Indicate if compression is supported.
Exclusion Filter
Create an exclusion filter if there are links the component monitor should not attempt to validate. It is a text matching filter.
Example that excludes any links to .png graphics files
Exclusion Filter: png
Ignore External Links
This option excludes external links from validation. External links are links that do not link back to the same second-level domain as the original URL.
Convert Value
Select the "Yes, convert returned value" option to display fields where you can select a common function or enter a custom formula. The Custom Conversion option provides basic arithmetic operators (+, -, *, /), plus built-in mathematical functions for more advanced conversions. See Convert values in data transformations for SAM component monitors.
Response Time Warning Threshold
Set the warning threshold conditions based on the response time. The response time is the time in milliseconds it takes SAM to determine that a component is not Down and to retrieve any statistical data.
Response Time Critical Threshold
Set critical threshold conditions based on the response time. The response time is the time in milliseconds it takes SAM to determine that a component is not Down and to retrieve any statistical data.
Statistic Threshold
Specify when a threshold that indicates a warning or critical level was breached. Logical operators are in the drop down followed by a blank field for you to enter the value of this threshold. For example: Less than 15 for warning, Less than 5 for critical. See Application Monitor Thresholds.
User Notes
Add notes for easy reference. You can access this field by using the variable, ${UserNotes}.
