Manage component monitors in SAM templates and application monitors
This section describes various tasks you can accomplish with component monitors, including:
- Create a new template with assigned component monitors
- Add component monitors to a new template and then assign that template to nodes
- Assign component monitors to a node
- Copy assigned component monitors to an application monitor template
- Copy assigned component monitors to an assigned application monitor
- Edit component monitors in assigned application monitors
- Delete component monitors in assigned application monitors
When adding a component monitor to a template, change its default name to identify exactly what's being monitored. For example, if you add a Windows Service Monitor, specify the service name.
This extra step clarifies the purpose of the component monitor when it appears in alerts and system messages later. To change a component monitor name, click Rename at the top of the Component Monitors section.
- Click Settings > All Settings > SAM Settings > Create New Template.
- Name the template then click the Add Component Monitors drop-down menu.
                                    Select a method for adding component monitors.
                                    The browsing method opens the Component Monitor Wizard. Add component monitors as needed.
- Click Submit to save the new template.
- Follow the steps in Assign templates to nodes manually to create application monitors.
- Click Settings > All Settings > SAM Settings > Manage Component Monitors within Templates.
- Select the component monitors you want to add to the new template.
- Click Create New Template.
- On the New Template page, provide a name and description for the template, and then configure the template and its component monitors.
- Click Save to return to the Manage Component Monitors within Templates page.
                            - Click Settings > All Settings > SAM Settings > Manage Assigned Component Monitors.
- Select the component type or assigned Application Monitor component monitors to list.
- Select the component monitors to assign to a node, and then click Assign to Node.
- Name the application and specify the polling frequency and polling timeout period.
- Click Next, and select the nodes that you want to assign the Application Monitor. Click Next.
- Enter or select the appropriate credentials, and click Assign Application Monitors.
- Select the component type or assigned Application Monitor whose component monitors you want to list.
- Select the component monitor(s) to copy to an assigned Application Monitor, then click Copy to Application Monitor Template.
- Select the template(s) to copy to and click Submit.
- Click OK.
- Select the component type or assigned Application Monitor whose component monitors to list.
- Select the component monitor(s) to copy to an assigned Application Monitor, then click Copy to Assigned Application Monitor.
- Select the Application Monitor(s) to copy to and then click Submit.
- Click OK.
Edit component monitors in an assigned application monitor
- Select the component type or assigned Application Monitor whose component monitors you want to edit.
- Select the component monitor whose assigned Application Monitor you want to edit.
- Click Edit Assigned Application Monitor.
- Edit the settings and then click Submit. The edited Application Monitor appears in the list of Assigned Application Monitors.
Delete component monitors in an assigned application monitor
- Select the component type or assigned Application Monitor component monitor(s) to delete.
- Select the component monitor(s) to delete.
- Click Delete, then click Yes to confirm deletion.
