Documentation forServer & Application Monitor
Configure Java application servers and JVMs for SAM monitoring
SAM includes several out-of-the-box application monitor templates that you can use to monitor Java application servers and JVMs via:
Predefined SAM templates include a JMX Monitor that communicates with Java servers to poll available managed beans (MBeans) and return results. You can also create custom JMX Monitors to poll specific MBeans.
Note the following details about configuring Java application servers and JVMs:
  • Set the JAVA_HOME environment variable for the server, as directed in vendor documentation. Otherwise, the following message may appear in SolarWinds Platform agent Python logs: "Exception: Unable to determine JAVA_HOME."
    Download a free GUI-based JVM environment monitoring tool, JConsole.
  • The following SolarWinds Platform features do not support JMX monitoring:
  • If SSL is enabled on a target server, include parameters to indicate KeyStore and TrustStore locations in the JMX Bridge config file, jsl64.ini. That default location is: C:\Program Files (x86)\SolarWinds\Orion\APM\jmxbridge\jsl\jsl64.ini.
Configuration steps vary, based on the type of target, as described in:
Additional resources include:
Scripts provided outside of the SolarWinds Platform Web Console are not supported under any SolarWinds support program or service. Scripts are provided AS IS without warranty of any kind. SolarWinds further disclaims all warranties including, without limitation, any implied warranties of merchantability or of fitness for a particular purpose. The risk arising out of the use or performance of the scripts and documentation stays with you. In no event shall SolarWinds or anyone else involved in the creation, production, or delivery of the scripts be liable for any damages whatsoever (including, without limitation, damages for loss of business profits, business interruption, loss of business information, or other pecuniary loss) arising out of the use of or inability to use the scripts or documentation.
Configure a standalone Java application server or JVM for remote monitoring
Windows
  1. Download and install the Java Development Kit (JDK) you want to use:
  2. Add a JAVA_HOME environment variable to the system with its path pointing to the Java installation folder.
    1. On the Advanced tab of the System Properties dialog box for Windows, click Environment Variables.
    2. Edit the JAVA_HOME variable to point to the JDK folder. For example, C:\Program Files\Java\jdk-16.0.0
  3. Navigate to the %JAVA_HOME%\jre\lib\management folder to configure authentication.
  4. If you want to use SNMP authentication:
    1. Rename the snmp.acl.template file to snmp.acl. Edit snmp.acl by replacing its content with:
      acl = {
      communities = public, private
      access = read-only
      managers = localhost, orion-server
      Where orion-server is the hostname of the SolarWinds Platform server.
    2. Grant access to the snmp.acl file only for the Administrator.
  5. If you want to use JMX authentication:
    1. Rename the jmxremote.password.templatefile to jmxremote.password.
    2. Edit jmxremote.password by replacing/adding its content with the following: samuser somepasswd
      where samuser is the user for the monitored JVM and somepasswd is the password.
    3. Edit jmxremote.access by replacing/adding its content with the following: samuser readonly
      where samuser is user for the monitored JVM, provided with read only permission.
    4. Copy jmxremote.access and jmxremote.password to a folder, for example c:\jmxremote\.
    5. Grant access to the jmxremote.password file only for the Administrator.
Linux
  1. Download and install JDK version 8 or later. See Update the JDK and JRE for Orion Platform products that utilize Java, including SAM and VMAN for details.
  2. Using a SolarWinds Platform agent, add a node.
  3. On the node, go to /etc/systemd/system/swiagentd.service.d/.*
    *If the directory does not yet exist, complete the following steps before moving on to step 4.
    1. Go to /etc/systemd/system/.
      Command: cd /etc/systemd/system/
    2. Create and open folder swiagentd.service.d.
      Command: mkdir swiagentd.service.d
      cd swiagentd.service.d
    3. Create the file override.conf.
      Command: touch override.conf
  4. Set your JAVA_HOME variable.
    1. Using a file editor such as Vi, open override.conf.
      Command: vi override.conf
    2. Copy and paste the following into the file:
    3. [Service]
      Environment="JAVA_HOME=path_to_java_home"
      where path_to_java_home is your JDK localization. For example, /usr/local/jdk1.0.8_221-amd64
    4. Save the changes.
    5. Run this command to apply settings and restart agent service:
      Command:
      sudo systemctl daemon-reload
      sudo systemctl restart agentd.service
  5. If you want to use SNMP authentication:
    1. Go to the $JAVA_HOME/jre/lib/management folder and rename the snmp.acl.template file to snmp.acl.
    2. Edit snmp.acl by removing all lines and writing the following:
      acl = {
      access = read-only
    3. Grant access to the snmp.acl file only for the root user. Run the following commands as the root user in your shell:
      # chown root.root $JAVA_HOME/jre/lib/management/snmp.acl
      # chmod 600 $JAVA_HOME/jre/lib/management/snmp.acl
  6. If you want to use JMX authentication:
    1. Go to the $JAVA_HOME/jre/lib/management folder and rename the jmxremote.password.template file to jmxremote.password.
    2. Edit jmxremote.password by replacing/adding the content with the following:
      samuser somepasswd
      where samuser is the user for the JVM monitored by SAM and somepasswd is the password.
    3. Edit jmxremote.access by replacing/adding the content with the following:
      samuser readonly
      where samuser is user for the JVM monitored and readonly - gives this read only permissions.
    4. Copy jmxremote.access and jmxremote.password to a folder, for example /jmxremote/.
    5. Grant access to the jmxremote.password file only for the root user. Run the following commands as the root user in your shell:
      # chown root.root $JAVA_HOME/jre/lib/management/jmxremote.password
      # chmod 600 $JAVA_HOME/jre/lib/management/jmxremote.password
    Agentless and SolarWinds Platform Agent for Windows polling use the JMX Bridge Service but the Linux agent does not use that service. Linux-based JMX queries run locally through the SolarWinds Platform agent itself.
Test a standalone Java application server or JVM
To test that a target server can respond to SNMP queries, add the following command to the Java command line:
-Dcom.sun.management.snmp.port=1161 -Dcom.sun.management.snmp.interface=0.0.0.0
For example:
java -Dcom.sun.management.snmp.port=1161 -Dcom.sun.management.snmp.interface=0.0.0.0 some_java_applet
In another window/shell, run the following command to test SNMP and the Java SE configurations:
snmpwalk -v 2c -c public 127.0.0.1:1161 1.3.6.1.4.1.42.2.145.3.163.1.1.2.11
The command should return a value similar to:
SNMPv2-SMI::enterprises.42.2.145.3.163.1.1.2.11.0 = Counter64: 4803352
To test if a target server can respond to JMX queries, add the following command to the Java command line to enable JMX on port 8686 using authentication:
-Dcom.sun.management.jmxremote -Dcom.sun.management.jmxremote.port=8686 -Dcom.sun.management.jmxremote.ssl=false -Dcom.sun.management.jmxremote.authenticate=true -Dcom.sun.management.jmxremote.password.file="c:\jmxremote\jmxremote.password" -Dcom.sun.management.jmxremote.access.file="c:\jmxremote\jmxremote.access"
For example:
java -Dcom.sun.management.jmxremote -Dcom.sun.management.jmxremote.port=8686 -Dcom.sun.management.jmxremote.ssl=false -Dcom.sun.management.jmxremote.authenticate=true -Dcom.sun.management.jmxremote.password.file="c:\jmxremote\jmxremote.password" -Dcom.sun.management.jmxremote.access.file="c:\jmxremote\jmxremote.access"some_java_applet
In a separate window or shell, run the following command to test JMX and the Java SE configurations:
%JAVA_HOME%\jdk16.0.0_3\bin\jconsole
In the jconsole window, select Remote Process, type 127.0.0.1:8686 and provide Username: sam and Password: somepasswd. After a successful connection, monitoring statistics should appear.
For reference, see Java arguments for remote JMX monitoring.
Configure JBoss EAP or WildFly servers for JMX monitoring
This section describes how to set up the following types of target servers for JMX monitoring:
  • JBoss Enterprise Application Platform (EAP)
  • WildFly
  • JBoss AS
Note the following details:
  • (Recommended) Use the SolarWinds Platform agent for Linux to monitor JBoss EAP or WildFly servers.
  • The JMX Bridge on the SolarWinds Platform server can be configured to monitor either JBoss EAP or WildFly target servers, but not both types simultaneously.
  • If running WildFly in domain mode, note that the default setting for JMX collection only allows JMX collection through the host collector using unique ports for each JVM. This default setting won't work with SAM, but you can configure WildFly to allow the collection of JMX from each JVM. See JMX Security, available at docs.wildfly.org.
Windows Service
  1. Edit %JBOSS_HOME%\bin\run.bat by adding the following lines, where %JBOSS_HOME% is the path to your JBoss installation:
    set "JAVA_OPTS=%JAVA_OPTS% -Dcom.sun.management.snmp.port=1161"
    set "JAVA_OPTS=%JAVA_OPTS% -Dcom.sun.management.snmp.interface=0.0.0.0"
    rem Setup JBoss specific properties
    set JAVA_OPTS=-Dprogram.name=%PROGNAME% %JAVA_OPTS%
  2. Register JBoss as a service by running: %JBOSS_HOME%\bin\service.bat -install
  3. Go to the Windows Services console
  4. Right-click the JBoss Application Server service.
  5. Click Properties.
  6. Switch to the Log On tab, and then click Log on as this account.
  7. Click Browse to locate the "Administrator" user, and then type the Administrator password twice.
  8. Click OK.
  9. Start the JBoss service.
See also:
Windows Command Line for JBoss EAP or WildFly
  1. Open %JBOSS_HOME%\bin\standalone.bat and navigate to the following section:
  2. Add the following lines immediately before the JBoss.Bootstrap.Environment section shown in the previous step, where:
    • %JBOSS_HOME% is the path to your JBoss installation,
    • ###.###.#.### is the IP address of the target server, and
    • X.X.X is a version of jar files for a specific JBoss server.
    set "JAVA_OPTS=%JAVA_OPTS% -Djboss.platform.mbeanserver"
    set "JAVA_OPTS=%JAVA_OPTS% -Djava.rmi.server.hostname=###.###.#.###"
    set "JAVA_OPTS=%JAVA_OPTS% -Dcom.sun.management.jmxremote.port=8686"
    set "JAVA_OPTS=%JAVA_OPTS% -Dcom.sun.management.jmxremote.ssl=false"
    set "JAVA_OPTS=%JAVA_OPTS% -Dcom.sun.management.jmxremote.authenticate=true"
    set "JAVA_OPTS=%JAVA_OPTS% -Dcom.sun.management.jmxremote.password.file="c:\jmxremote\jmxremote.password""
    set "JAVA_OPTS=%JAVA_OPTS% -Dcom.sun.management.jmxremote.access.file="c:\jmxremote\jmxremote.access""
    set "JAVA_OPTS=%JAVA_OPTS% -Djboss.modules.system.pkgs=org.jboss.logmanager"
    set "JAVA_OPTS=%JAVA_OPTS% -Djava.util.logging.manager=org.jboss.logmanager.LogManager"
    set "JAVA_OPTS=%JAVA_OPTS% -Xbootclasspath/p:%JBOSS_HOME%\modules\system\layers\base\org\jboss\logmanager\main\jboss-logmanager-X.X.X.Final-redhat
  3. For WildFly 13.0.0 or later, or JBoss EAP 7.2 or later, add the following line to the parameters above.
    set "JAVA_OPTS=%JAVA_OPTS% -Xbootclasspath/p:%JBOSS_HOME%\modules\system\layers\base\org\wildfly\common\main\wildfly-common-X.X.X.Final.jar"
  4. Start JBoss EAP by running %JBOSS_HOME%\bin\standalone.bat.
Windows Command Line for JBoss AS
  1. Navigate to the following section of %JBOSS_HOME%\bin\run.bat:
    • %JBOSS_HOME% is the path to your JBoss installation, and
    • ###.###.#.### is the IP address of the target server.
    set "JAVA_OPTS=%JAVA_OPTS% -Djavax.management.builder.initial=org.jboss.system.server.jmx.MBeanServerBuilderImpl"
  3. Start JBoss by running %JBOSS_HOME%\bin\run.bat.
Linux for JBoss EAP or WildFly
  1. Open $JBOSS_HOME/bin/standalone.sh and navigate to the following section:
    • $JBOSS_HOME is the path to your JBoss installation,
    • X.X.X is a version of jar files for specific JBoss server.
      JAVA_OPTS="$JAVA_OPTS -Djboss.platform.mbeanserver"
      JAVA_OPTS="$JAVA_OPTS -Djava.rmi.server.hostname=###.###.#.###"
      JAVA_OPTS="$JAVA_OPTS -Dcom.sun.management.jmxremote.port=8686"
      JAVA_OPTS="$JAVA_OPTS -Dcom.sun.management.jmxremote.ssl=false"
      JAVA_OPTS="$JAVA_OPTS -Dcom.sun.management.jmxremote.authenticate=true"
      JAVA_OPTS="$JAVA_OPTS -Dcom.sun.management.jmxremote.password.file="/jmxremote/jmxremote.password""
      JAVA_OPTS="$JAVA_OPTS -Dcom.sun.management.jmxremote.access.file="/jmxremote/jmxremote.access""
      JAVA_OPTS="$JAVA_OPTS -Djboss.modules.system.pkgs=org.jboss.logmanager"
      JAVA_OPTS="$JAVA_OPTS -Djava.util.logging.manager=org.jboss.logmanager.LogManager"
      JAVA_OPTS="$JAVA_OPTS -Xbootclasspath/p:$JBOSS_HOME/modules/system/layers/base/org/jboss/logmanager/main/jboss-logmanager-X.X.X.Final.jar"
    JAVA_OPTS="$JAVA_OPTS -Xbootclasspath/p:$JBOSS_HOME/modules/system/layers/base/org/wildfly/common/main/wildfly-common-X.X.X.Final.jar"
  4. Start JBoss EAP by running $JBOSS_HOME/bin/standalone.sh.
Linux for JBoss AS
  1. Open $JBOSS_HOME/bin/run.sh, and navigate to the following section:
    # Display your environment
    echo "========================================================================="
    echo ""
    echo "  JBoss Bootstrap Environment"
    echo ""
    echo "  JBOSS_HOME: $JBOSS_HOME"
    echo ""
    echo "  JAVA: $JAVA"
    echo ""
    echo "  JAVA_OPTS: $JAVA_OPTS"
    echo ""
    echo "  CLASSPATH: $JBOSS_CLASSPATH"
    echo ""
    echo ""
  2. Add the following lines to $JBOSS_HOME/bin/run.sh immediately before the JBoss Bootstrap Environment section shown in the previous step, where:
    JAVA_OPTS="$JAVA_OPTS -Djavax.management.builder.initial=org.jboss.system.server.jmx.MBeanServerBuilderImpl"
    JAVA_OPTS="$JAVA_OPTS -Dcom.sun.management.jmxremote.password.file=" /jmxremote/jmxremote.password""
    JAVA_OPTS="$JAVA_OPTS -Dcom.sun.management.jmxremote.access.file=/jmxremote/jmxremote.access""
  1. When finished, start JBoss by running $JBOSS_HOME/bin/run.sh.
Configure a standalone Java application server or JVM for GlassFish monitoring
The following information was created based on Glassfish 3.1.
  1. Run the GlassFish Application Server.
  2. In a web browser, navigate to: http://hostname:4848 where hostname which is the name of your GlassFish server.
  3. In the left panel, click Configurations: server-config.
  4. In the main window, click JVM settings.
  5. Click the JVM Options tab.
  6. Use the Add JVM Option to enter the following values, one by one:
    • Dcom.sun.management.jmxremote
    • Djava.rmi.server.hostname=###.###.#.###, where ###.###.#.### is IP address of GlassFish server.
    • Dcom.sun.management.jmxremote.port=8686
    • Dcom.sun.management.jmxremote.ssl=false
    • Dcom.sun.management.jmxremote.authenticate=true
    • Dcom.sun.management.jmxremote.password.file="c:/jmxremote/jmxremote.password"
    • Dcom.sun.management.jmxremote.access.file=" c:/jmxremote/jmxremote.access"
  7. Click Save.
  8. Restart the GlassFish server.
Configure a standalone Java application server or JVM for IBM WebSphere monitoring
The following information was created based on IBM WebSphere 8.0. Note that WebSphere uses its own JDK, installed at %WEBSHERE_HOME%\java, where %WEBSHERE_HOME% is the path to your WebSphere installation.
  1. Run the IBM WebSphere Application Server.
  2. In a web browser, navigate to: https://hostname:9043 where hostname is the name of the WebSphere server.
  3. In the left panel, click Expand Servers and Server types.
  4. Click WebSphere Application Servers.
  5. In the main window, click your server.
  6. In the Server Infrastructure section, expand Java and Process Management.
  7. Click Process Definition.
  8. In the Additional Properties section, click Java Virtual Machine.
  9. In Generic JVM Arguments, add the following commands, where ###.###.#.### is the IP address of the WebSphere server:
    This command enables JMX monitoring without authentication.
    -Djavax.management.builder.initial= -Djava.rmi.server.hostname=###.###.#.### -Dcom.sun.management.jmxremote -Dcom.sun.management.jmxremote.port=8686 -Dcom.sun.management.jmxremote.ssl=false -Dcom.sun.management.jmxremote.authenticate=false
  10. Save your changes.
  11. Restart the IBM WebSphere Application Server.
If errors occur, you can manually change/restore the configuration, as stored in the following file:
%WEBSPHERE_HOME%\profiles\your_profile\config\cells\your_cell\nodes\your_node\servers\your_server\server.xml
Configure a standalone Java application server or JVM for Oracle WebLogic monitoring
The following information was created based on Oracle WebLogic 8.0. Note that WebLogic uses its own JDK, installed at %MIDDLEWARE_HOME%\jdk*, where %MIDDLEWARE_HOME% is the path to your WebLogic installation.
Windows
Edit the following file:
%MIDDLEWARE_HOME%\user_projects\domains\<your_domain>\bin\startWebLogic.cmd,
where %MIDDLEWARE_HOME% is the path to your WebLogic installation. Add the following lines:
set "JAVA_OPTIONS=%JAVA_OPTIONS% -Djavax.management.builder.initial=weblogic.management.jmx.mbeanserver.WLSMBeanServerBuilder"
set "JAVA_OPTIONS=%JAVA_OPTIONS% -Dcom.sun.management.jmxremote"
set "JAVA_OPTIONS=%JAVA_OPTIONS% -Dcom.sun.management.jmxremote.port=8686"
set "JAVA_OPTIONS=%JAVA_OPTIONS% -Dcom.sun.management.jmxremote.ssl=false"
set "JAVA_OPTIONS=%JAVA_OPTIONS% -Dcom.sun.management.jmxremote.authenticate=true"
set "JAVA_OPTIONS=%JAVA_OPTIONS% -Dcom.sun.management.jmxremote.password.file="c:\jmxremote\jmxremote.password""
set "JAVA_OPTIONS=%JAVA_OPTIONS% -Dcom.sun.management.jmxremote.access.file=" c:\jmxremote\jmxremote.access""
The result should resemble this example:
call "%DOMAIN_HOME%\bin\setDomainEnv.cmd" %*
set "JAVA_OPTIONS=%JAVA_OPTIONS% -Dcom.sun.management.jmxremote.password.file=" c:\jmxremote\jmxremote.password""
set SAVE_JAVA_OPTIONS=%JAVA_OPTIONS%
This file is created by the SolarWinds Platform Configuration Wizard. Any changes will be lost the next time the wizard runs.
Restart the WebLogic Server.
Linux
$MIDDLEWARE_HOME/user_projects/domains/<your_domain>/bin/startWebLogic.sh,
where $MIDDLEWARE_HOME is the path to your WebLogic installation. Add the following lines:
JAVA_OPTIONS="$JAVA_OPTIONS-Djavax.management.builder.initial=weblogic.management.jmx.mbeanserver.WLSMBeanServerBuilder"
JAVA_OPTIONS="$JAVA_OPTIONS -Dcom.sun.management.jmxremote"
JAVA_OPTIONS="$JAVA_OPTIONS-Dcom.sun.management.jmxremote.port=8686"
JAVA_OPTIONS="$JAVA_OPTIONS-Dcom.sun.management.jmxremote.ssl=false"
JAVA_OPTIONS="$JAVA_OPTIONS-Dcom.sun.management.jmxremote.authenticate=true"
JAVA_OPTIONS="$JAVA_OPTIONS-Dcom.sun.management.jmxremote.password.file="/jmxremote/jmxremote.password""
JAVA_OPTIONS="$JAVA_OPTIONS-Dcom.sun.management.jmxremote.access.file="/jmxremote/jmxremote.access""
${DOMAIN_HOME}/bin/setDomainEnv.sh $*
JAVA_OPTIONS="$JAVA_OPTIONS-Dcom.sun.management.jmxremote"
SAVE_JAVA_OPTIONS="${JAVA_OPTIONS}"
This file is created by the Configuration Wizard. Any changes will be lost the next time the wizard runs.
Configure a standalone Java application server or JVM for Apache Tomcat monitoring
The following information was created based on Apache Tomcat 7.0.
Windows Service
  1. Open the Tomcat configuration by clicking Start > All Programs > Apache Tomcat > Configure Tomcat.
  2. Open the Java tab, and add the following lines to the Java Options box:
  3. Click Apply.
  4. Go to the Windows Services console.
  5. Right-click the Apache Tomcat service.
  6. Click Properties.
  7. Click the Log On tab, and then click Log on as this account.
  8. Navigate to the Administrator user and type the Administrator password twice.
  9. Click OK.
  10. In the Tomcat Configuration window, return to the General tab, and then start the service.
  1. Open the file %TOMCAT_HOME%\bin\catalina.bat, and add the following lines to the Debug, Run and Start sections, where %TOMCAT_HOME% is the path to your Tomcat installation:
    :doDebug
    shift
    :doRun
    shift
    :doStart
    shift
  2. Run %TOMCAT_HOME%\bin\startup.bat to start Tomcat.
Linux
  1. Open $TOMCAT_HOME/bin/catalina.sh and add the following lines into Debug, Run and Start sections, where %TOMCAT_HOME% is the path to your Tomcat installation:
    JAVA_OPTS="$JAVA_OPTS -Dcom.sun.management.snmp.port=1161"
    JAVA_OPTS="$JAVA_OPTS -Dcom.sun.management.snmp.interface=0.0.0.0"
    if [ "$1" = "debug" ] ; then
    if $os400; then
    elif [ "$1" = "run" ]; then
    shift
    elif [ "$1" = "start" ] ; then
    if [ ! -z "$CATALINA_PID" ]; then
  2. Run $TOMCAT_HOME/bin/startup.sh command to start Tomcat.
The following table describes Java arguments that you can use to enable remote JMX monitoring on standalone Java application server or JVMs:
Java argument Description
-Djava.rmi.server.hostname=###.###.#.### Indicates the IP address of the Remote Method Invocation (RMI) server.
-Dcom.sun.management.jmxremote Enables remote JMX monitoring.
-Dcom.sun.management.jmxremote.port=8686 Indicates which port the JMX module will use to accept JMX connections.
-Dcom.sun.management.jmxremote.ssl=false Indicates if SSL is used.
-Dcom.sun.management.jmxremote.authenticate=true Indicates if authentication is used (recommended).
If not using authentication, change the value to false.
c:\jmxremote.password
Indicates where the password file is stored.
Only add this line if using authentication.
c:\jmxremote.access
Indicates where the access file is stored.
To learn more about arguments, see Java Documentation.
