Documentation forSolarWinds Observability SaaS
Storage monitoring
In SolarWinds Observability SaaS, storage arrays are monitored alongside infrastructure entities. You can bring storage arrays monitored with SolarWinds Observability Self-Hosted into SolarWinds Observability SaaS as storage array entities.
Requirements
  • To use a Network Collector, you need Network Collector 2025.1.1 and later
  • To use Platform-connected SolarWinds Observability Self-Hosted, you need the SRM add-on license and you need to enable the Storage Observability when configuring the Platform Connect.
  • SolarWinds Observability SaaS supports almost the same arrays as SRM. See Supported arrays (A-H) and Supported arrays (I-Z).
    Some storage entities, such as NetApp Storage Virtual Machines, and some details monitored by SolarWinds Observability Self-Hosted are not supported by SolarWinds Observability SaaS. Storage monitoring support may be extended in the future.
Add storage entities for monitoring
You have the following options to specify the storage arrays to monitor:
  • For Network Collector versions 2025.4 and later, you can use the Add Data wizard directly in SolarWinds Observability SaaS.
  • For earlier versions of Network Collector, use the Network Collector Web Console.
  • You can add Platform-connected SolarWinds Observability Self-Hosted in the SolarWinds Observability Self-Hosted web console and enable them in SolarWinds Observability SaaS Platform Connect wizard.
Add Data wizard in SolarWinds Observability SaaS
The supported storage arrays can be added using the Add Data wizard in SolarWinds Observability SaaS.
  1. Go to Add Data -> Infrastructure -> Add storage array.
  2. Select an existing Network Collector or deploy a new one.
  3. Select a vendor and device type. If the selected device type supports multiple polling methods, select the preferred one:
    • An onboard provider is management software or an API built directly into the storage hardware's firmware or management controller, requiring no extra installation.
    • An external provider is a separate software package (often an SMI-S Provider) that must be installed on a dedicated external server to translate the array's data into a format compatible with SolarWinds Observability SaaS.
  4. Specify the storage array's hostname or IP address.
  5. Configure the credentials.
    The primary credential types used for storage array monitoring are determined by the communication protocol required by the array vendor:
    • SMI-S Credentials: Used for devices that communicate via the Storage Management Initiative Specification (SMI-S) protocol, whether the provider is onboard or external. SMI-S credentials consist of a display name, username, and password.
    • API Credentials: Many modern arrays use a proprietary or RESTful API for monitoring. The credentials consist of a username and password and, in some cases, API tokens.
    • SNMP Credentials: Used for network devices and some NAS systems, with different versions offering varying levels of security.
      • SNMP v1/v2c: Uses a simple "community string" (often "public" or "private" by default) for authentication.
      • SNMP v3: Offers enhanced security with a username, authentication method (for example MD5 or SHA), and privacy protocol (for example AES or DES).
    Some storage arrays require a combination of different credential types for monitoring (for example, SNMP + API or SMI-S + API). All credentials are stored centrally and can be reused by multiple arrays or providers. The existing credentials can be accessed through Settings -> Credentials -> Infrastructure.
    Advanced settings such as port, the interop namespace or the array namespace can be updated for all credential types (where applicable). The default values represent the most common values for the selected storage array type.
  6. Specify arrays for monitoring.
    Depending on the chosen polling method (onboard or external provider), the discovery process can return one or multiple arrays of the given type. Select and import the ones that are not yet monitored.
The Network Collector is a tool that collects data from your entities and sends it to SolarWinds Observability SaaS. The Network Collector was originally designed to collect data for network devices, but its features have been extended to support other entities, such as storage arrays. See Add a network device
  1. Log in to your Network Collector Web Console using an account with administrator privileges.
  2. Click Settings > All Settings, and then click Add Storage Device in the Getting Started section.
  3. Select the array type and click Next.
  4. On Choose Data Source, configure the provider.
    Required steps depend on the array you are adding. See details for your array type and provider in Add arrays to SRM.
  5. Click Test Connection to verify your settings.
  6. On Choose Data Targets, select storage arrays to monitor and click Next.
  7. Verify the settings and click Finish.
After the first poll, the details are sent to SolarWinds Observability SaaS.
If you have storage arrays in SolarWinds Observability Self-Hosted and want to monitor them in SolarWinds Observability SaaS, set up Platform Connect to stream data from SolarWinds Observability Self-Hosted to SolarWinds Observability SaaS.
To use Platform Connect, a commercial SolarWinds Observability Self-Hosted license must be activated on your SolarWinds Platform server.
To monitor storage arrays, you also need a SRM add-on license.
  1. Copy or create an API token (Ingestion type), found in the settings area of SolarWinds Observability SaaS. See API Tokens for details.
  2. In the SolarWinds Platform Web Console settings, open Platform Connect. Follow the on-screen prompts to install and configure the SolarWinds Observability Agent, entering the API token created earlier. See Connect SolarWinds Observability Self-Hosted to SolarWinds Observability SaaS with Platform Connect for details.
  3. On the Configure Agent screen of the Platform Connect wizard, ensure that Storage Observability is enabled.
After Platform Connect setup is completed, storage arrays are available in SolarWinds Observability SaaS.
Get an overview of monitored storage entities
For an overview of monitored storage array entities, click Infrastructure > Storage.
The Overview tab displays health state distribution for all storage entities and sub pages for storage arrays, storage pools, LUNs and NAS volumes with summary capacity widgets for all entity types.
Some metrics, such as capacity-related details, are only polled every 6 hours: If you cannot see data, you might need to change the time setting to at least "Past 6 hours".
The Entities tab displays a list of main storage entities with the most important performance and capacity metrics. Click the tile with entities you want to review.
Click an entity to display more details about it.
Review details for individual storage array entities
Click a storage entity to display the details page for it. The details page may include the following tabs.
Only tabs relevant for the selected storage entity are displayed.
  • Overview: This tab shows the most important details, such as HS, IOPS, and throughput performance metrics. It includes widgets for row and usable capacity summary, and summary widgets for child entities (Pools, LUNs, NAS volumes). The Overview also includes:
    • Additional details for physical disks include disk size or disk status.
    • Additional details relevant for the array include vendor, model, serial number, vendor status, or firmware.
  • Performance: This tab displays performance metrics, such as IOPS, throughput, and cache hit ratio. It is also available for storage pools, LUNs, and NAS volumes.
  • Sensors: This tab displays a summary of all hardware health sensors for the storage array, including their status and values (if available).
  • Storage Pools: This tab displays details about storage pools in the array.
  • LUNs: This tab displays details about storage pools in the array.
  • NAS Volumes: This tab displays details about NAS volumes in the array.
  • File Shares: This tab lists all file shares hosted on the storage array or NAS volume with the most important metrics and attributes, such as file share type, used and free capacity. Click a file share to see more details in the Inspector Panel , such as the file server IP addresses or capacity summary.
Details pages for storage pools, LUNs, and NAS volumes
Similar to storage array details page, these pages display the most important capacity and performance metrics together with entity meta data and additional details, such as RAID type and Provisioning type (Thick/Thin).
For storage pools, there are also entity pages with LUNs and NAS volumes on the respective pool.
Alert on storage array entities
You can create alerts on all relevant entities and their metrics/attributes using out-of-the-box templates.
  1. Click Alerts > Alerts Settings and click the Templates tab.
  2. Filter the templates to only display templates relevant for storage monitoring. In the search field, enter this filter and review available templates.
    entityType:[StoragePool, StorageArray, StorageLUN, StorageVolume]
  3. Customize a template to create the alert you need. See Create a metric or attribute value alert.
