Documentation forSolarWinds Observability SaaS
SolarWinds Observability Agent installation parameters
Review available parameters for stand-alone installation.
Installation parameters for Linux
Parameter Optional/
Required
Description
SWO_URL optional
The correct endpoint for your organization.
The default value is na-01: North American AWS data center
UAMS_ACCESS_TOKEN required An access token used to register the Agent.
UAMS_BIND_IDENTITY optional
Persist the given UUID identity as the Agent ID override.
UAMS_BIND_NEW_IDENTITY optional
Persist a new, randomly generated UUID as the Agent ID override.
UAMS_HTTPS_PROXY optional
The proxy only for the Agent
Use a proxy IP address, hostname, or domain name in one of the following formats:
  • http://proxyAddress
  • http://proxyAddress:port
  • http://user:password@proxyAddress:port
The proxy value must include the used protocol for the proxy, such as http:// or https://.
UAMS_IS_EPHEMERAL optional Marks an Agent as ephemeral. Ephemeral Agents are automatically removed from SolarWinds Observability SaaS when they are disconnected for at least 24 hours. Use this parameter for temporary Agents.
UAMS_MANAGED_LOCALLY optional
Supported value: true
Set to true to install the Agent as a locally-managed Agent.
By default, the configuration source for Agents is set to Remote.
UAMS_METADATA optional Custom metadata to be sent to the cluster on the first registration.
UAMS_OVERRIDE_HOSTNAME optional A name that will override the default hostname.
env UAMS_ACCESS_TOKEN="<access_token>" \
UAMS_BIND_IDENTITY="<client_id_in_UUID_format>" \
UAMS_BIND_NEW_IDENTITY="true" \
UAMS_HTTPS_PROXY="<http_or_https_proxy>" \
UAMS_IS_EPHEMERAL="true" \
UAMS_MANAGED_LOCALLY="true" \
UAMS_METADATA="role:host-monitoring" \
UAMS_OVERRIDE_HOSTNAME='<override_hosntame>' \
SWO_URL='<swo_url>' \
bash -c "$(curl -sSL https://agent-binaries.cloud.solarwinds.com/uams/latest/uamsclient_install.sh)"
Installation parameters for Windows script-based installation
Parameter Optional/
Required
Description
-AccessToken required An access token used to register the Agent.
-BindIdentity optional
-BindNewIdentity optional
-HTTPSProxy optional
-IsEphemeral optional Marks an Agent as ephemeral. Ephemeral Agents are automatically removed from SolarWinds Observability SaaS when they are disconnected for at least 24 hours. Use this parameter for temporary Agents.
-ManagedLocally optional
-Metadata optional Custom metadata to be sent to the cluster on the first registration.
-OverrideHostname optional A name that will override the default hostname.
-SwoUrl optional
[Net.ServicePointManager]::SecurityProtocol = "Tls11, Tls12"; irm https://agent-binaries.cloud.solarwinds.com/uams/latest/uamsclient_install.ps1 | iex; install -AccessToken "<access_token>" -BindIdentity "<client_id_in_UUID_format>" -BindNewIdentity "true" -HTTPSProxy "<http_or_https_proxy>" -IsEphemeral "true" -ManagedLocally "true" -Metadata "role:host-monitoring" -OverrideHostname "<override_hosntame>" -SwoUrl "<swo_url>"
Installation parameters for Windows Installer
Parameter Optional/
Required
Description
ACCESSTOKEN required An access token used to register the Agent.
SWO_URL optional
msiexec /i uamsclient.msi ACCESSTOKEN="<access_token>" BIND_IDENTITY="<client_id_in_UUID_format>" BIND_NEW_IDENTITY="true" HTTPS_PROXY="<http_or_https_proxy>" IS_EPHEMERAL="true" MANAGED_LOCALLY="true" METADATA="role:host-monitoring" OVERRIDE_HOSTNAME='"<override_hostname>"' SWO_URL="<swo_url>"
