Documentation forSolarWinds Observability SaaS
Add Fortinet orchestrators and edge devices
Add Fortinet FortiManager SD-WAN orchestrators, edge devices, and FortiEdge Cloud wireless controllers and edge devices to SolarWinds Observability.
For troubleshooting, see Troubleshoot SD-WAN and wireless controllers.
Supported devices
  • Fortinet FortiManager (both Cloud and on-premises)
  • FortiEdge Cloud wireless controllers
Requirements
  • Network Collector 2024.4.1 or later
  • Edge devices and orchestrator must be monitored using the same Network Collector.
  • Edge discovery for Fortinet FortiManager devices requires Network Collector 2024.4.1 or later.
    A Fortinet FortiManager orchestrator is limited to 250 requests/5 seconds for a polling engine.
  • Edge discovery for FortiEdge Cloud devices requires Network Collector 2025.2 or later.
  • Monitoring FortiManager tunnels requires Network Collector 2025.4 or later.
  • Monitoring on-premises Fortinet FortiManager requires Network Collector 2026.2 or later.
Add Fortinet FortiManager or FortiEdge Cloud wireless controller
  1. In SolarWinds Observability SaaS, click Add Data at the top.
  2. In the Add Data dialog, click the Network tab and click Fortinet orchestrators and edges.
  3. On Select Orchestrator, review the options, ensure that Add a new orchestrator is selected.
  4. Select the Fortinet solution to monitor and click Next.
    • Select Fortinet FortiManager to add a Fortinet SD-WAN orchestrator.
    • Select FortiEdge Cloud to add a FortiEdge Cloud wireless controller.
  5. Select an existing network collector or deploy a new one.
  6. On Define Orchestrator Node, provide the polling hostname or IP address of the node.
    Optional settings
    • To identify the device in SolarWinds Observability SaaS, specify a display name.
    • To add a custom tag to the device, click Add Tag and specify the key and the value for the tag. You can also add tags to the device later on the device details page under the Overview tab.
  7. Provide details for the selected Fortinet solution and click Next.
    • If you are adding a FortiEdge Cloud wireless controller, provide your Username, Password, and AccessTokenUrl.
    • If you are adding Fortinet FortiManager Cloud on a Network Collector 2026.1 or earlier, provide your Username, Password, and ClientID.
    • If you are adding Fortinet FortiManager (Cloud or on-premises) on Network Collector 2026.2, use one of the following authentication options:
      • Cloud API - Enter your AppID, Client Secret, Client ID, and Token URL.
      • API Token - Enter your pre-defined Fortinet FortiManager API key or token.
      • Username & Password - Enter your Fortinet FortiManager user credentials.
      See FMG JSON API Introduction in Fortinet documentation for information on the authentication methods.
  8. On Summary, review the information and click Submit.
    The device is added for monitoring. To monitor edge devices, complete the steps for Discover and import edge devices for a Fortinet orchestrator.
  3. On Select Orchestrator, specify the edge devices to be discovered and click Next.
    1. Select Use a monitored orchestrator.
    2. Select the orchestrator you want to add edges for.
    SolarWinds Observability SaaS now starts discovering edge devices managed by the selected orchestrator. This may take a few minutes.
  4. On Select edge devices..., select the devices you want to add for monitoring and click Next.
    If an edge device is already monitored by the selected Network Collector, the selection is blocked. The checkbox grayed out.
  5. On Summary Edges, review the information on devices to be added and click Submit.
    The edge device(s) are imported for monitoring.
