Troubleshoot network devices
Data not displaying in SolarWinds Observability SaaS
If SolarWinds Observability SaaS does not display data for monitored devices, make sure the devices have the correct category specified in the Network Collector.
In the Network Collector Web Console, click Settings > Manage Nodes.
Select the device and click Edit Properties.
Scroll down to Node Category, make sure Network is selected, and submit your changes.
Flow data not displaying in SolarWinds Observability SaaS
Flow data should appear in the SolarWinds Observability SaaS in about 5 minutes after the data are available on the Network Collector.
If you are getting other network device data, check out the following troubleshooting steps.
Verify that flow export is set up correctly. See Netflow data coming in to Orion server but not showing up in Orion Web Console.
Verify that flows are correctly stored in the database (Flow Storage Database) used by your Network Collector. See NTA shows Data Not Available.
Check how many flows are coming to the Network Collector:
On the server hosting the Network Collector, open the Windows Performance Monitor.
Click the plus button to add performance counters, search for SolarWinds NetFlow and add Rows Inserted Per Second.
If the number of Rows Inserted Per Second is constantly over 500, the SolarWinds Observability Agent (Agent) service might be overloaded.
Verify that the SolarWinds Observability Agent service sending the data to SolarWinds Observability SaaS is not overloaded.
On the server hosting Network Collector, open Services and check the CPU and memory usage for SolarWinds.SOC.Service.exe.
If CPU or memory usage is high, the service might be overloaded.
To address the overloaded Agent issue, stop sending flow data for non-critical nodes to SolarWinds Observability SaaS.
Log in to the Network Collector Web Console and click My Dashboards > Flow Sources.
Switch Flow sources management to Nodes. To do so, select Nodes in the drop-down box next to the Flow sources management.
Select all nodes and click Drop traffic. The Network Collector will stop processing flow data and no flow data will be sent to SolarWinds Observability SaaS.
Restart the SolarWinds.SOC.Service.exe service. This will mean that there will be a gap in data sent from the Network Collector.
On the Flow sources management view, select a few critical nodes and click Store traffic. After a few minutes, the data should start appearing in the SolarWinds Observability SaaS.
No flow data is displayed from a domain
If no data is displayed for domains on Flows tabs, check the Filters tab. The data might be filtered out.
If the data is not being filtered out, check that resolving and storing IPv4 hostnames is enabled on the Network Collector.
Log in to the Network Collector Web Console, click Settings > All Settings, and click NTA Settings in the Product specific settings grouping.
Scroll down to DNS and NetBIOS Resolution settings and ensure that the Resolve and store IPv4 host names immediately when a flow record is received option is selected.
No new data about monitored network devices
If you cannot see new data for monitored metrics, you might need to reset the database.
Resetting the database which stores the data (soc.db, in the sqlite format) might be necessary in the following cases:
System time or database time changes caused by system time provider or human error change time markers in the database as a result, the data may not be exported until the system changes the markers again.
soc.dbfile corruption
To reset the database, complete the following steps:
On the Network Collector database server, stop the
swiuamsclientdservice. -
Search for the database file
soc.db. By default, the file is located in the following location:C:\ProgramData\SolarWinds\UAMSClient\plugin-storage\network-collector\soc.dbIf the database cannot be deleted, ensure that the
SolarWinds.SOC.Serviceprocess is not running. -
Restart the
swiuamsclientdservice. The database file will be recreated.
