Add Meraki orchestrators and edge devices
Add Meraki SD-WAN orchestrators and edge devices to SolarWinds Observability.
For troubleshooting, see Troubleshoot SD-WAN and wireless controllers.
Requirements
Network Collector 2025.1 or later
Edge devices and orchestrator must be monitored using the same Network Collector.
Add a Meraki orchestrator
In SolarWinds Observability SaaS, click Add Data at the top.
In the Add Data dialog, click the Network tab and click Meraki orchestrators and edges.
On Select Orchestrator, review the options, ensure that Add a new orchestrator is selected and click Next.
Select an existing network collector or deploy a new one.
On Define Orchestrator Node, provide the polling hostname or IP address of the node.
Optional settings
- To identify the device in SolarWinds Observability SaaS, specify a display name.
 - To add a custom tag to the device, click Add Tag and specify the key and the value for the tag. You can also add tags to the device later on the device details page under the Overview tab.
Provide an API Token. Log in to your Meraki orchestrator and copy the API Token you want to use to identify your orchestrator in SolarWinds Observability.
On Summary, review the information and click Submit.
Discovered organizations are displayed as drop-down items. Select the organization to monitor.
The device is added for monitoring. To monitor edge devices, complete the steps for Discover and import edge devices for a Meraki orchestrator.
On Select Orchestrator, select Use a monitored orchestrator, select the orchestrator you want to add edges for, and click Next.
On Select edge types, select the type of edges to be monitored and click Next.
At least one edge type must be selected. By default, Appliances and Switches are selected.
SolarWinds Observability SaaS now starts discovering all edge devices managed by the selected orchestrator. This may take a few minutes.
On Select edge devices..., select the devices you want to add for monitoring and click Next.
If an edge device is already monitored by the selected Network Collector, the selection is blocked. The checkbox is grayed out.
On Summary Edges, review the information on devices to be added and click Submit.
