View all defined alerts
The Alert Settings page lists all alerts that are currently defined. Use this page to view high-level information and to manage alert definitions.
Open the Alert Settings page
In the left pane, click Alerts > Alert Settings.
Locate specific alert definitions
To locate specific alert definitions, you can sort, apply filters, or search by name:
Click a column heading to sort the list by name, severity, description, or whether it is currently active.
Apply filters to show only a subset of the alert definitions, such as all active alerts or all disabled alerts.
If the Filters pane is closed, click the filter icon
to open it. -
Select one or more filters to apply them.
The Alert Settings page lists only the alert definitions that meet all filter criteria.
To search for an alert definition, enter part of the alert name in the Search Alerts box. The Alert Settings page lists only the alert definitions that include the string you entered.
View alert definition details
Click an alert definition name to open the details view for that alert definition. The details view displays information on the following tabs:
The Overview tab includes the following information:
The current status and active time.
Information about the entities that have triggered the alert.
Alert details, including the description, severity, scope, and conditions.
The most recent changes to the alert.
The History tab shows when this alert was triggered in the past.
The Metrics tab shows a chart of the metric related to the alert, giving a clear view of the timeline.
The Log tab displays logs from the past 30 days, as well as any emerging log patterns that could help analyze anomalies and triggers.
The Active Alerts on this Entity tab shows all alerts that pertain to a particular entity.
There is a limit of 1000 active alerts per alert definition. See Active alert limit for more information.
In case of a lag or a network issue that may cause scheduled tasks to time out, SolarWinds Observability SaaS keeps track and displays the triggering events from the past 15 minutes when the connection is reeastablished.
On any tab that lists triggering entities, you can click an entity name to display information that can help you troubleshoot why the alert was triggered for that entity.
Other actions
From the Alert Settings page, you can also:
- Create a new alert definition, either by completing the entire wizard or duplicating a similar alert
- Mute an alert for a specified period of time or until it is resolved
- Acknowledge an alert
- Disable or enable an alert
- Clear a triggered alert
- Edit an alert definition
- Delete an alert definition
