Documentation forSolarWinds Observability SaaS
Manage observed network devices in SolarWinds Observability SaaS
You can manage network devices and servers monitored by a Network Collector directly from SolarWinds Observability SaaS or using the Network Collector web console.
You can access the management options from the Network area overview, from the Entity Explorer, or from device details views.
Managing network devices and servers monitored by a network collector, requires Owner, Admin, or Viewer permissions. See Permissions.
Pause collecting data for monitored devices
  1. Find the network device you want to pause collecting metrics for in the Network area overview or in the Entity Explorer.
  2. To pause collecting the metrics:
    • Click the vertical ellipsis at the end of the entity row and select Pause metrics collection.
      To access the action from a network device details page, click the vertical ellipsis in the top right and select Pause metrics collection.
    • Select one or more network devices and click the Pause metrics collection button.
  3. Confirm the change.
  4. No new data will be collected for the selected entity/entities but you will still see the network devices in SolarWinds Observability SaaS. No alerts will be triggered for devices with paused metrics collection. The icon in the Monitoring column will change to Paused.
Resume collecting data for monitored devices
  1. Find the network device you want to resume collecting metrics for in the Network area overview or in the Entity Explorer.
  2. To resume collecting the metrics:
    • Click the vertical ellipsis at the end of the entity row and select Resume metrics collection.
      To access the action from a network device details page, click the vertical ellipsis in the top right and select Resume metrics collection.
    • Select one or more network devices, and click the Resume metrics collection button.
  4. Data for the selected entity/entities be collected and displayed in SolarWinds Observability SaaS. Alerts will be triggered if the trigger condition occurs. The icon in the Monitoring column will change to Active.
Import discovered entities
In SolarWinds Observability SaaS Area Overviews
Starting with Network Collector 2024.2.10, you can see newly discovered entities or child entities directly in SolarWinds Observability SaaS. You can also import the updates directly from area overviews.
  1. In SolarWinds Observability SaaS, click Network > Discovered in the left navigation.
    To import discovered updates for hosts monitored by a Network Collector, click Infrastructure > Hosts > Discovered tab.
    The Discovered tab shows all discovered entities (network devices or hosts) on a connected Network Collector with their status:
    • Imported: Entities that are already monitored.
    • Found: Entities that were discovered and are not monitored yet.
    • Changed: Entities with new elements, such as interfaces or volumes, discovered.
    Click an entity to display more details, such as a list of discovered interfaces, volumes, or other discovered elements (highlighted with a plus icon).
    Use filters to filter discovered entities by their properties, such as status, machine type, or discovery profile.
  2. Import discovered entities as network devices or as hosts. See Import other devices.
    1. Expand Filters, select Network Devices in Device type and Found in Status.
    2. Review the discovered devices, select devices to be imported and click Import as Network Device.
      To add devices as hosts, select Hosts in the Device type filter, select hosts to be imported, and click Import as Host.
In SolarWinds Observability SaaS Settings
Starting with Network Collector 2023.4, you are notified about discovery results run on your Network Collector or SolarWinds Observability Self-Hosted instance connected via Platform Connect.
In SolarWinds Observability SaaS, click Settings > Network Discoveries. You can review details on discoveries, such as the discovery status, frequency, last run time, or the number of newly discovered and changed items.
  • To re-run a discovery, click the vertical ellipses at the end of the discovery row and click Run now.
  • To import the newly discovered or updated items for monitoring, click the vertical ellipsis and click Import all results.
List and change resources monitored for network devices or hosts monitored by a Network Collector
  1. Find the device or host, click the vertical ellipsis, and click List Resources.
    Network devices
    • In Network area overview, click the vertical ellipsis at the end of the device row on the Overview tab.
    • In network device details, click the vertical ellipsis in the top right corner of the page.
    Hosts monitored by a Network Collector
    • In the Infrastructure area overview, click Hosts.
    • On Overview, click the filter icon, find NC Host, and select Enabled. Only hosts monitored by a Network Collector are displayed.
    • Click the vertical ellipsis at the end of a host row.
    The resources available on the device/host are displayed.
    Resource loading times depend on the number of resources associated with the device.
  2. Select or clear boxes for resources as appropriate and save your changes.
Remove devices
When you remove a device from SolarWinds Observability SaaS, the entity is removed but the historical data is retained. Calculations using this data are not affected.
  1. Select the entity you want to remove either in the Network area overview or in the Entity Explorer. Management buttons for your selection will be displayed above the entities table.
    You can remove network devices, servers, or hosts monitored by a Network Collector.
    You can remove multiple network devices and servers simultaneously.
  2. Click Remove, and then click Remove again in the confirmation dialog.
  3. As an alternative, you can hover over the table row, click the vertical ellipses () in the far-right column, and select the option in the menu. On device details view, find the vertical ellipsis in the top-right corner of the view.
The entity is removed both from the Network Collector and SolarWinds Observability SaaS.
If the entity re-appears in the Entity Explorer, delete it again. This can be caused by latency, long message queues, or other connection issues.
Manage credentials
In SolarWinds Observability SaaS, you can add credentials, use existing credentials while adding network devices or discovering your network, or delete credentials.
Supported protocols and credential types: SNMPv2, SNMPv3, WMI
Customize device type
A device type describes the primary role of a network device, such as a router, switch, firewall, or wireless controller. Device types help you organize, filter, and display devices in your network inventory.
SolarWinds Observability assigns device types automatically based on collected data, such as routing tables, interfaces properties, or SNMP OIDs. In some cases, the detected type may not be accurate. You can manually change the device type to reflect the device's role.
Changing a device type affects how the device appears in list views and summary widgets. It does not change data displayed on the Network Device Details page, which always reflects the types detected by the Network Collector.
Examples of when to customize device type
  • ICMP‑only devices: Devices added using ICMP provide limited data, so the device type cannot be determined automatically.
  • Unsupported firewall vendors: The Network Collector automatically detects only supported firewall vendors. If you use other firewall vendors, set firewall as the device type manually.
  • Devices reporting multiple roles: Some devices return SNMP data for more than one role, such as acting as both a firewall and a wireless controller. You can update the device type to reflect its primary function.
Edit device type for a single device
  1. In SolarWinds Observability SaaS, click Network > Devices or go to the device details page.
  2. Click the vertical ellipsis for the device and select Edit.
  3. In the Device Type section, select one or more device types to assign to the selected device.
    • Always select at least one device type.
    • If a device has no specific type, select Other.
  4. Click Update to apply the changes.
Bulk edit device type for multiple devices
You can also modify device types for multiple devices at once.
  1. In SolarWinds Observability SaaS, click Network > Devices.
  2. Select the devices you want to change the device type for.
  3. Click Edit Device Type.
  4. In the Device Type section, select one or more device types to assign to the selected devices.
    • When you select multiple devices, the types you choose are assigned to all selected devices.
    • If the device had any device types assigned, they are removed and replaced with the selected device type(s).
    • You cannot restore device types to their original detected values in bulk. To restore defaults, edit each device individually.
  5. Click Update to apply the changes.
Restore automatically detected device type
You can restore the automatically detected default device types only for individual devices.
  3. Click Restore Default next to the Device Type.
  4. Save your changes.
