Create an alert definition
When you define an alert, you specify what conditions trigger the alert and what notifications it sends.
Triggered alerts on an entity can affect the entity's health. See Entity health to determine how triggered alerts affect an entity's health and how you can customize the impact.
Types of alerts
You can create alerts that are triggered by metric or attribute values, log files, or anomaly events. The type of alert you create determines how you define the condition or conditions that trigger the alert.
Metric alerts are triggered when a metric or attribute value crosses a threshold, is not being reported, or meets another condition that you specify. You can define two types of metric alerts:
Entity Metric alerts monitor the specified metric or attribute values on one or more entities. For example, you can be alerted when the response time for a website is above a threshold, or when the state of a network device is Critical or Down.
You can also create a parent-child relationship alert. This alert is triggered on a parent entity when the specified metric or attribute value of a child entity exceeds a threshold. For example, you can be alerted when the temperature of the hardware sensor on a network device is too high.
Metric Group alerts are triggered when the aggregated value of a metric crosses a threshold. These alerts are not associated with specific entities or an entity type. Use Metric Group alerts to monitor metrics that are obtained through an integration but are not associated with an entity. You can also create Metric Group alerts if you want know when the aggregated value of a metric crosses a threshold (for example, high latency or high request volume), but you do not want an alert for each individual issue.
Log alerts monitor incoming log messages, including syslog messages, SNMP traps, audit logs, and Windows event logs. The condition that triggers the alert can be defined based on a combination of factors, including the source IP address, text included in the message, and the severity level.
Event notifications are triggered when a metric value on one of the specified entities is significantly outside its normal range.
Create a metric or attribute value alert
To create an alert that is triggered based on the value of one or more metrics and attributes, complete the following tasks.
Task 1: Specify the alert details
Open the Active Alerts page (Alerts > Active Alerts) or the Alert Settings page (Alerts > Alert Settings).
In the upper-right corner, click Create Alert.
The Create Alert wizard opens.
Complete the Details page:
Enter a name to identify the alert and, optionally, enter a description of what the alert does.
(Optional) To help users resolve issues quickly, enter a runbook URL. This URL opens a document (for example, a wiki page) that describes what actions should be taken when the alert is triggered. This link is included in the alert notification.
Specify the alert severity.
The alert severity determines how the alert affects an entity's health state when it is triggered.
If you do not want the alert to be enabled immediately, click the slider to disable it. You can enable it later.
- Click Next to open the Conditions page.
Task 2: Specify the condition type and scope
Under Condition type, click Metric condition.
Under Alert on, select one of the following:
To set a threshold on a metric or attribute associated with one or more entities (an entity metric alert), select Entity. Then continue with step 3.
To set a threshold on a metric without selecting entities (a metric group alert), select Metric group. Then continue with Task 3.
Under Select a scope, select the type of entity or an entity group. Then specify which entities you want the alert to belong to.
If you are creating alerting on a parent entity based on the value of a child entity (a relationship alert), select the entity type of the parent relationship.
To select Do this All entities of the specified type -
Under Scope by, click All.
Specific entities -
Under Scope by, click Selected <entityType>.
Under Select <entityType>, click the drop-down menu and then click each entity you want to select.
All entities whose name contains a certain string -
Under Scope by, click Contains text.
Under Contains text, enter the string that the entity name must include. The case must match.
The alert applies to all entities of the specified type whose name includes that string. After the alert is created, it automatically applies to any new entities with that string in the name.
All entities whose name does not contain a certain string -
Under Scope by, click Does not contain text.
Under Does not contain text, enter a string that the entity name must not include. The case must match.
The alert applies to all entities of the specified type whose name does not include that string. After the alert is created, it automatically applies to any new entities without that string in the name.
Entities based on the value of one or more metrics or attributes -
Under Scope by, click Search query.
Click in the Search query field to display the available metrics and attributes.
Click a metric or attribute, and then click a value.
For example, if the entity type is Website, select
featuresand thenrumto select all website entities whose metrics are collected by a RUM script. -
Repeat as needed to specify multiple metrics or attributes.
If you include multiple values for the same metric or attribute, an entity is included if it has either value. For example, if you select
healthScore.category:badandhealthScore.category:unknown, the alert includes all entities of the selected type with a health state of bad or unknown.If you include multiple metrics or attributes, an entity is included if it has all metric or attribute values. For example, if you select
healthScore.category:badandfeatures:rum, the alert includes website entities with a bad health state and whose metrics are collected by a RUM script.
Task 3: Define one or more conditions
Define one or more conditions that trigger the alert. You can define a condition based on:
- The value of a metric
- The value of an attribute
- The value of a metric or an attribute on a child entity
An alert can include multiple types of conditions.
Define a condition based on a metric value
In the drop-down menu at the top of the Condition box, select Metric.
Under Metric, select the metric whose value determines if this condition is met. Enter part of the metric name to filter the list. For metric descriptions, see Metrics for SolarWinds Observability SaaS entities.
If you selected an entity type, only the metrics available for that entity type are listed. When you select a metric, a graph shows the value of the metric for up to five of the selected entities. To show or hide an entity, click the entity name in the legend below the graph. To display information about different entities, click Select from Scope and choose the entities.
If you selected Metric Group, all metrics are available. When you select a metric, a graph shows the aggregated values for that metric.
(Optional) Use an attribute associated with the selected metric to further narrow the scope.
Under Included (for a value that must be present) or Excluded (for a value that cannot be present), click Add.
Select an attribute associated with the selected metric.
Select an operator, and then specify the values that must be present or that cannot be present for the condition to be met:
If you select contains, enter a string that is present in the values you want to select.
For example, if the entity type is Network Device and the metric attribute is
sw.collector.Nodes.Display.Name, enterNXto limit the alert to network devices whose display name includesNX. -
If you select equal to, click one or more values in the third drop-down menu to select those values.
For example, let's say you are creating an alert to monitor the response time of websites whose metrics are collected by a probe. You want this alert to be triggered only when the probe is sent from the region of Europe. Under Included, click Add. Then select
probe.regionas the attribute,equal toas the operator, andEuropeas the value. -
Under Trigger when metric is, define the threshold for the metric. Based on your specifications, the alert is triggered when the metric value is above or below a certain level, or when it is not being reported.
You can also mark the Use Dynamic Threshold checkbox. The dynamic threshold functionality takes into consideration historical data and patterns, and sets the threshold automatically based on them. The past values are tracked to learn the normal operating range. See Alert condition dynamic threshold for more information on when and how to use the dynamic threshold feature.
For example, if it's expected that an event would occur typically during a certain period of time it would not trigger the alert, but if it occurs outside of that typical time, the alert is triggered.
The "Not reporting" metric condition can be defined for metrics, metric groups, or metric tags grouped by entities or tags. When a metric group is selected, an alert is triggered whenever a metric stops reporting for any of the grouped entities or tags during the time frame defined under During last.
Under During last, choose the time frame used for evaluating the alert condition, and specify how the values collected during that time frame are aggregated.
For example, if the time frame is the past hour and the aggregation method is average, the alert would be triggered if the average of the values collected during the past hour crossed the condition threshold.
After you define a condition, a red dotted line on the graph shows whether any of the entities or the aggregated metric value would trigger the alert during the selected period. In the example below, the Support website would have triggered the alert when the average response time went above 1600 ms.
Define a condition based on an attribute value
To see many of the attributes for an entity type, look at the filters available for that entity type in the Entity Explorer. Hover over the
to see the source name for that attribute from the collected data.
In the drop-down menu at the top of the Condition box, select Attribute.
Under Attribute, select the attribute whose value determines if this condition is met.
Select an operator, and then specify the values that trigger this alert.
If you choose the in operator, you can enter multiple values, separated by commas. Enclose strings in quotation marks. For example:
"Critical", "Unreachable", "Down"For all other operators, enter a single value. Do not enclose strings in quotation marks. For example:
DownThe selected attribute determines which operators are available. (For example, "higher than" is not available for an attribute whose values are strings.)
If the attribute value is this data type These operators are available Boolean
- equal to
- not equal to
Enter the value as
trueorfalse.Float
Integer
- equal to
- not equal to
- higher than
- lower than
- higher than or equal to
- lower than or equal to
- in
String
- equal to
- not equal to
- in
Define a condition based on the value of a metric or an attribute on a child entity
In the drop-down menu at the top of the Condition box, select Relationship.
This option is available only if, under Select a scope, you selected an entity type that has child entities (for example, Network Device).
Under Relationship, select the child entity type that triggers the alert.
Under Scope by, specify which child entities you want to trigger the alert.
To select Do this All child entities of the specified type -
Specific child entities -
Under Scope by, click <entityType>.
Under Trigger when count is, specify the number of child entities that must meet the condition to trigger the alert.
For example, say a network device provides a service to a large number of end users. You don't want an alert every time one interface is down, but you do want an alert if more than 10 are down. Select
higher than, and enter10. -
Define the condition that must exist on the child entity to trigger the alert. Depending on the type of triggering condition, see:
Add another condition
To add another condition, do one of the following:
Click Add rule. Then select an operator by clicking AND (all conditions must be true) or OR (at least one condition must be true).
To add a condition that is similar to the first one and must also be true, click the vertical ellipsis
and then click Duplicate. A condition with the same definition is added, connected by the AND operator. Edit the condition as needed.
It is possible to introduce several nested conditions that relate to the first rule you create. When defining an alert condition, you can add either a rule or a rule group. Adding a group creates a separate subsection of two rules, connected to the original rule with an operator. You can create more groups from within a group, adding a further level of nesting. You can view the condition in text form in the alert details view, under Conditions. A group is displayed as a set of rules enclosed by brackets.
Delay alert triggering and clearing
By default, alerts are triggered as soon as the condition is met. You can however introduce a delay, so that the alert is triggered only when the condition is true for a certain specified period of time. If the condition is cleared before this time elapses, the alert is reset. This can reduce noise and increase reliability, prevent duplicate incidents in integrations (ServiceNow, PagerDuty).
Additionally, you can also introduce a delay to the clearing of the alert. See Manually clear an active alert for more information.
Set the alert triggering and clearing delay
When setting up the alert, go to the Conditions tab.
Under Other Settings, locate Delay alert triggering by and Delay alert clearing by and enter the delay duration.
Set a recovery threshold
By default, metric alerts are cleared as soon as the trigger condition is no longer met. The recovery threshold option addresses this by allowing you to set a separate threshold for clearing the alert. The alert remains active until the metric moves beyond the recovery threshold. This helps ensure that alerts represent meaningful changes in system health rather than short-lived metric fluctuations.
For example, when you configure an alert to trigger when CPU utilization exceeds 90%, you can configure a recovery threshold of 75% so that the alert clears only after CPU utilization drops below 75%, rather than clearing as soon as it falls below 90%.
To use this option, enable and define the value of the recovery threshold when defining the alert condition.
Task 4: (Optional) Specify related context information
The Related context dropdown menus located under the conditions section can be used to obtain more contextual information based on the monitored entity's state. This is helpful in identifying what and why happened or identifying what may be affected. You can quickly and easily see all necessary information from the notification itself.
There are three categories for which you can select additional information to include:
Attributes
Attributes
Name
namespaceName
Parent
Entity type
Kubernetes namespace
Kubernetes cluster
Children
Entity type
Kubernetes pod
The recommended checkboxes are selected by default. You receive contextual notifications without extra configuration, but you can also customize your settings or disable the additional information.
Example notification with additional context information:
Alert TRIGGERED: Critical
EC2Host example-host-1
CPUUtilization: 92.5%
Upstream (Parent):
AWS Account: 123456789012
Region: us-east-1 | AZ: us-east-1a
Attributes:
Instance Type: m5.xlarge | Environment: Dev
Downstream (Children):
Hosts: payment-api (service degraded)
Task 5: (Optional) Trigger separate alerts based on a property value
Under Group alert data for selected attribute, select a property if you want to trigger a separate alert for each value of that property. The property value is included in the alert notification. In some situations, this additional information can help you troubleshoot the issue that triggered the alert.
For example, let's say you create an alert to monitor the response time for a website, and you select the property probe.city. If the issue occurs in multiple cities, a separate alert is triggered for each city. If both the probe in London and the probe in Tokyo detect a high response time, two alerts are triggered.
The drop-down menu lists the properties of the metric that is selected in the alert condition. If the alert has multiple conditions with different metrics, the drop-down menu lists only properties that are common to all the metrics. If the metrics have no common properties, the drop-down menu is empty.
Task 5: Specify the notifications
Click Next to open the Actions tab, and define one or more actions to be performed when this alert is triggered:
Click Add.
Select the service that will send the notification or perform an action.
An action can be, for example, a message sent to a Slack channel, a PagerDuty alert, or a Webhook request.
Select one or more configurations to define the action to be performed. To define a new configuration, click Add a New Configuration and enter the required information. (See Notification Services settings for more information about what to enter.)
Trial users are limited to 10 notification configurations per alert definition. Users with an active subscription have a limit of 20 notification configurations. Configurations that have been set up previously are not affected and do not cease to function unless modified.To see the details of an existing action or notification, click Settings > Notification Services, and select a service.
Enable the Aggregate option to receive multiple alerts of this alert definition in a single notification, instead of a separate notification for each triggered alert. You can set up the aggregation time window.
To send notifications or perform actions using more than one service, click Add. Then select the service and configurations.
If you want to notify recipients when the alert condition no longer exists, select Send an additional notification when the Alert is cleared.
Click Next.
Task 6: Review
On the Summary page, review the alert definition and make changes if necessary.
Click Create.
Create a log alert
You can create a log alert from the Active Alerts or Alert Settings page, like other alert types. You can also perform a search in the Logs Explorer, and then create an alert that automatically populates the condition with the current search criteria.
Do one of the following to open the alert creation wizard:
Start from the Logs Explorer, and use the current search criteria as the condition:
In the left pane, click Logs to open the Logs page.
Enter search criteria in the search box.
Click the Create alert for this search query icon
.The Create Quick Alert dialog opens.
Start from an alerts page:
If you do not want the alert to be enabled immediately, click the slider to disable it. You can enable it later from the Alert Settings page.
Click Next.
The Conditions page opens. If you opened the wizard from the Logs Explorer, the condition defaults to the search query you entered there.
Under Trigger on following query, add the condition to search for in logs, or verify the condition sent from the Logs Explorer.
For more information about syntax, see Logs Explorer.
Under Trigger when the number of logs is, specify the following, and then click Next:
The threshold, or the number of logs that must meet the condition to trigger the alert.
The time period to search logs for the specified condition.
For example, if the threshold is
higher than 1during the last30 minutes, the alert is triggered if two or more log files meet the condition in a 30-minute time period. -
Click Add.
Click Next.
On the Summary page, review the alert definition, and then click Create.
Use a saved search as the alert query
Instead of entering a query under Trigger on following query, you can base the condition on a saved search. When you select one, the Use Saved Search dialog shows the query the saved search contains and asks how you want to use it:
Use query as-is: The query text is copied into the alert at creation time. Later edits to the saved search do not apply to the alert.
Keep query synced: This option enables live-sync queries. The alert always evaluates against the latest query in the saved search. Updates apply automatically.
Access to saved searches depends on your organization role, and saving a search requires access to at least one Group. See Save and manage searches.
Re-enable an alert whose saved search was deleted
Deleting a saved search that alert definitions use disables those alerts. Before the saved search is deleted, SolarWinds Observability SaaS lists the alert definitions that use it, and you confirm the deletion by clicking Delete and disable alerts. Deleting a saved search will only disable alerts saved with live-sync and will not disable alerts saved using query as-is.
A disabled alert reports that its linked saved search was deleted and that the saved search query was removed. To re-enable the alert, open its condition, draft a new query or select an existing saved search under Trigger on following query, and then save the alert. You can also click Unlink to remove the reference to the deleted saved search.
Alert on anomaly events
Under Condition type, click Event condition.
Under Event type, select Anomaly.
Under Select a scope, select the type of entity. Then specify which entities of the selected type you want to alert on.
Under Select <entityType>, leave the default value of <entityType>.
Specific entities -
Select the metric to alert on.
The alert will be triggered when this metric value is an anomaly. The graph shows the number of anomalies that occurred during the selected time period.
Click Add.
Click Next.
Alert on Kubernetes events
You can create a Kubernetes event alert from the Active Alerts or Alert Settings page, like other alert types. You can also create a quick alert from the Events tab of the Kubernetes cluster details view of the Entity Explorer.
Start from the Entity Explorer:
In the left pane, click Explore to open the Entity Explorer.
From the entity type drop-down menu, select Kubernetes Clusters.
Click the Kubernetes cluster name to open the Entity Details page, and click the Events tab.
Hover over the event you want to create an alert for, click the vertical ellipsis (
) on the right, and select Create alert.The Create Quick Alert dialog opens.
Under Event type, select Kubernetes events.
Specific entities -
If you opened the wizard from the Entity Explorer, the condition defaults to the search query you entered there.
Under Trigger on following query, add the tags to search for in Kubernetes events, or verify the tags sent from the Entity Explorer.
Under Trigger when the number of events is, specify the following, and then click Next:
The threshold, or the number of events that must meet the condition to trigger the alert.
The time period to search events for the specified condition.
higher than 1during the last30 minutes, the alert is triggered if two or more Kubernetes events meet the condition in a 30-minute time period. -
Click Add.
Click Next.
Alert on APM error events
Create an alert based on APM error events from the Active Alerts or Alert Settings page, like other alert types. An error event is created for every span with the ERROR status (otel.status_code = ERROR) and for every span that has a Span Exception event captured. If the span has multiple Exception events, multiple APM error events will be created, one for every exception.
The APM error event attributes sw.error.type and sw.error.message provide context for APM error events, easing triage. Both attributes are enabled in the Alert wizard when you select Service as the Entity Type. SolarWinds Observability derives sw.error.* attributes for error events as follows:
sw.error.type:
Uses
exception.typewhen the event represents an exception.
Otherwise, the algorithm uses the first available value from:
error.type -
http.response.status_code -
gRPC status code --> gRPC
Connect RPC error code --> RPC
JSON-RPC error code --> JSON-RPC
If none of these are present, the value is set to Unknown.
sw.error.message:
The algorithm uses exception details (for example,
exception.message) when the event represents an exception.
If no exception message is available, it uses the first available value from:
OpenTelemetry status description
HTTP status code and description
gRPC status code and description
To create an APM error event alert, complete these steps:
Under Event type, select Service events.
Specific entities -
Under Trigger on following query, add the tags to search for in APM error events.
higher than 1during the last30 minutes, the alert is triggered if two or more APM error events meet the condition in a 30-minute time period. -
Click Add.
Click Next.
Create an alert based on an existing alert
To quickly create a new alert that is similar to an existing alert, you can duplicate the existing alert definition and then make changes.
In the left pane, click Alerts > Alert Settings.
The Alert Settings page lists all configured alert definitions.
Locate the alert you want to duplicate.
Hover over the table row, and click the vertical ellipsis (
) in the far-right column. Then click Duplicate.The Create Alert Wizard opens. The default name is the original alert name with
- Copyappended to it. All other settings are the same as the original alert. -
Enter a different name, and update other settings as needed. Depending on the type of alert, see one of the previous sections for more information.
Create an alert based on a template
To facilitate creating alerts for the most common use cases, SolarWinds Observability SaaS lets you use pre-filled alert templates configured with various frequently used conditions. The templates can be fine-tuned and adapted to your specific needs.
At the top of the page, click the Templates tab.
Select the template that best suits your needs, hover over the table row, and click the vertical ellipsis (
) in the far-right column. Then click Create Alert.The Create Alert Wizard opens.
Relevant templates are also suggested within onboarding wizards or in vertical ellipsis menus for specific entities.
Alert timezone configuration
The alert notifications time is set to UTC time by default. To display the time in your local time, you can change the global default by setting a specific timezone in Settings > Feature Settings > Alerts > Timezone. The setting applies to all Email, Slack, Teams, and other notification channels.
Separate per channel timezones can also be set, by going to Settings → Notification Services → specific channel → Create Configuration and choosing a timezome from the Notification timezone dropdown.
The per-channel timezones take priority. If a per-channel timezone is selected, that timezone is displayed. If no per-channel timezone is selected, the global default is displayed. If neither is configured, the system falls back to UTC.
