Monitor custom metrics from HTTP endpoints via API
Collect data from devices, services, or other HTTP endpoints. You can define custom metrics, configure how data is polled, and store the results for analysis. SolarWinds Observability SaaS makes it easy to build API monitors from scratch or using pre-filled templates.
Observe monitored metrics
In SolarWinds Observability SaaS, click Infrastructure > Software and activate the API Monitor tab. The tab lists all available monitors, with details, such as the collected metric prefix, number of monitored metrics, type, and last update information. Here, you can also switch from List View to Gallery View.
Ensure that the Polling toggle is on (green) in the row containing your API monitor.
From the API Monitor tab,
Click Name of the monitor in either List or Gallery View to open the Metrics Explorer displaying all metrics with the given Metric Prefix.
In List View, click on the row to open the Inspector Panel and view metrics.
In Gallery View, expand the row, and the metrics will appear under the monitor name.
Additionally, you can use the vertical ellipses menu to view metrics.
Use the Poll Metrics Now option in the vertical ellipses menu to manually refresh metric data from either the table row or the details view.
In the Metrics Explorer, click a metric to display a graph showing polled values.
Once selected, the details view (or Inspector Panel) displays metrics charts for each polled metric monitored under in the metric prefix, as well as the Status reports and any error messages, which are shown at the top.
API monitors send requests from source IP addresses that are not static and can change at any moment. For the identification of HTTP requests coming from a SolarWinds Observability API Monitor, use headers. You can also configure authentication to increase security.
Create an API monitor
Click Create API Monitor.
Create from Scratch - choose the Create from scratch option card to customize (automatically takes you to Step 3).
OR
Create using a Template - choose one of the vendor option cards to select a pre-filled template on the next screen.
On the Vendor screen, select the radio button for the template name you would like to configure. You can also search for specific templates in the search field.
Click Next to advance to Step 3.
OR
Import a Template - choose the Import a template option card to upload an API monitor template in JSON format.
Import templates only from trusted and verified sources. Unverified templates may contain configurations that may negatively impact your observability data, integrations, or monitoring setup.
On the Import a template screen drag and drop, or click the center panel to browse for and select your template JSON.
On the Settings screen:
Provide a Name for the monitor. The name you enter, combined with the SolarWinds Observability prefix, is used for the metrics prefix collected by the API monitor currently being configured. You can use it to find your monitors in the Metrics Explorer. Templates have a default name that you can update.
(Optional) Add a description to explain the monitor's purpose. Templates will include a default description that you can also customize.
(Optional) Specify a custom polling interval.
By default, custom monitors are polled every two minutes. If you want to change the polling frequency, click Use Custom Polling Interval and specify the new polling interval.
Click Next.
If you are using a pre-filled Template, skip to Step 5. If you are creating a monitor from scratch or importing a JSON template file, complete this step first.
On Cloud or On-prem, select the radio button for the location of the endpoint you will monitor -- either in the cloud or on-prem.
If you select Cloud, click Next to move on to Step 5 to create the request.
If you select On-prem, click Next to deploy a SolarWinds agent on the following screen(s).
On Assign Agent, create a new agent or use an existing agent.
Firewall settings: The agent must be able to reach the internet, primarily over TCP 80/443.
Create a new Agent: Select the first radio button, then click Next.
On Token, create or select an API ingestion token to use by doing either of the following:
Select Generate New Token and enter an Ingestion Token Name, and then click Next.
Or
Select Use Existing Token, and select an ingestion token from the list; click Next.
On Install Agent, follow the instructions to run the generated script as an admin on your target machine.
Once the script has been run, click Next to create your request in Step 5.
Use an existing Agent: Search for, then select the Agent from the list; click Next to create your request in Step 5.
On Create Request, specify the request you want to send to the URL.
Select the HTTP method, GET or POST, enter the Request URL, or instance where applicable.
Select the authentication type and enter required details.
No Authentication - default option
Basic Authentication
Select Existing to choose credentials from the drop-down list or leave New selected to specify a new set of credentials.
To create a new set, provide a name for the set, user name, and password. Click Save Credential. The new credentials set will be added to the list and selected.
Bearer Authentication
To create a new set, provide a name for the set and token. Click Save Credential. The new credentials set will be added to the list and selected.
API Key
To create a new set, provide a name for the set, Key, and Value. Click Save Credential. The new credentials set will be added to the list and selected.
OAuth 2.0
To create a new set, provide the following:
Credential name
Access Token URL (pre-filled with default)
URL Parameters - instance or tenant ID
Client ID
Client Secret
(Optional) Scope
(Optional) Advanced Options, including Client Authentication and Additional Parameters
Specify headers for your request. Click Add Header and provide the Name and Value for the header. Repeat for all headers you want to include in the request.
Some headers, such as Host, Cookie, Content-Length, and User-Agent, might be restricted due to security concerns, internal use, or inapplicability.
(Optional for POST requests) In the Request Body field, enter a valid JSON body of up to 500,000 characters.
Click Send Request. The response (headers and content) are displayed on the screen in the Response section.
In the Response section, select metrics to monitor.
Review the response. You can see a toggle next to items you can monitor.
Click the Monitor toggle for a metric you want to monitor.
If values returned will be an array, the Name listed includes a drop-down arrow to list all fields in the array. You can select individual array fields, or optionally, toggle on Monitor next to the parent Name to Monitor the number of items in the this field array.
In the Configure Metric pop-up, enter a display name. Review the read-only box below to see the metric name. This is the name you will see in the Metrics Explorer.
If you use camel case or blanks in the display name, the metric name will be adjusted. Blanks are replaced with an underscore, uppercase letters are transformed to lowercase and are preceded with an underscore. For example, the display name
Rate LimitorRateLimitwill be reflected in the metric name asrate_limit. -
Metric Configuration Options
If the values returned will be in string format, such as
trueorfalse, use the Convert String to Numeric OPTIONAL fields to add the string values and map them to numeric values. For example, map "OK" to 0, "Error" to 1, and all other values including null to -1. The strings are automatically replaced by and stored as the corresponding numbers. You can also use the numeric values in alert definitions. -
For arrays, optionally, you can toggle to Apply to all items in array, which reports a metric for every item in the array instead of a single item within the array.
Choose additional metric attributes. Optionally, you can select up to 5 metric attributes for the metric, which are used as labels to filter and group metric data (Response Content and Diagnostic metrics only).
Click Save and complete the steps for all metrics to monitor.
When you have added all metrics you want to monitor, click Next.
(Optional) On Select Entity, you can link polled metrics to an already monitored entity.
Toggle on Link to an existing entity.
Select an entity type from the list.
Select the entity.
Click Next.
Review the Summary and click Save. You will return to the API Monitors tab where you can see your new monitor.
Edit API monitors
If you want to rename a monitor, change the URL, add or remove a metric it specifies, edit the monitor.
Changing the polling source from cloud to on-prem or vice versa for existing API monitors is not permitted.
Find the monitor to edit, click the vertical ellipsis at the end of its row and select Edit. This starts the API monitor wizard.
On Settings, you can:
Change the prefix used for polled metrics: Adjust the Name and check the change in the read-only field below.
Changing the name also changes the metric prefix. As a result, the data is polled from scratch and historical data is not linked to the metric anymore.
Change the polling frequency: Click the slider and fill in the required polling frequency.
On Create Request, you can make the following changes:
Change the request URL
Adjust the headers.
Add or remove monitored metrics: Click Send Request and use the sliders to adjust what is monitored.
On Select Entity, you can link to an existing entity.
Review the summary and complete the wizard.
Stop/re-start polling data for a monitor
If you want to temporarily stop polling metrics for a monitor, toggle off Polling.
Find the monitor to edit, click the Polling toggle to the off (grey) position in the table row. Data for all metrics in the monitor will stop being polled.
To start polling data for the monitor again, in the same table row click the Polling toggle to the on (green) position.
Delete API monitors
If you want to remove an API monitor, delete it.
Find the monitor to delete, click the vertical ellipsis at the end of its row and select Remove.
Click Remove in the confirmation modal.
The monitor is deleted and new data for the metric is not polled anymore. Historical data is still accessible, you can find it in the Metrics Explorer using the deleted metric name.
Bulk actions
You can complete bulk actions for multiple API monitors at once, including start polling, stop polling, and permanently remove.
For example, if you want to multiple monitors to stop polling, for each monitor, click the check box at the beginning of the row in the API Monitors table, then click Disable button above the list in the table.
Removing monitors is permanent, and requires a confirmation in the modal that opens after clicking the Remove button.
Export API monitors
Export monitor definitions as JSON files for sharing or import into other environments. Select Export available from vertical ellipses menu in the table row for the monitor you wish to export.
