- Release Notes
- Patch Manager 2025.1 release notes
- Patch Manager 2024.4 release notes
- Patch Manager 2024.2 release notes
- Patch Manager 2024.1.1 release notes
- Patch Manager 2024.1 release notes
- Patch Manager 2023.4.2 release notes
- Patch Manager 2023.4.1 release notes
- Patch Manager 2023.4 release notes
- Patch Manager 2023.3.1 release notes
- Patch Manager 2023.3 release notes
- Patch Manager 2023.2.2 release notes
- Patch Manager 2023.2.1 release notes
- Patch Manager 2023.2 release notes
- Patch Manager 2023.1.1 release notes
- Patch Manager 2023.1 release notes
- Patch Manager 2022.4 release notes
- Patch Manager 2022.3 release notes
- Patch Manager 2022.2 release notes
- Patch Manager 2020.2.6 release notes
- Patch Manager 2020.2.5 release notes
- Patch Manager 2020.2.4 release notes
- Patch Manager 2020.2.1 release notes
- Patch Manager 2020.2 release notes
- Patch Manager 2019.4.2 release notes
- Patch Manager 2019.4 release notes
- Patch Manager 2.1.7 release notes
- Patch Manager 2.1.6 release notes
- Patch Manager 2.1.5 release notes
- Patch Manager 2.1.4 release notes
- Patch Manager 2.1.3 release notes
- Patch Manager 2.1.2 release notes
- Patch Manager release history
- Install or Upgrade
- Get Started
- Patch Manager Getting Started Guide
- Get started with Patch Manager
- About the Patch Manager Administrator Console
- Configure your Patch Manager environment
- Verify the WSUS installation
- Verify the services and applications
- Add a WSUS server to Patch Manager
- Remove a WSUS server from Patch Manager
- (Optional) Provision additional server roles
- (Optional) Create Automation Server routing rules
- Populate the default credential ring
- Create a WSUS publishing certificate for third-party publishing
- Configure the group policy to enable third-party updates
- Refresh the group policy
- Select and download the updates
- Generate an inventory of systems to update
- Approve, push, and schedule the updates
- Generate reports
- Best practices for using Patch Manager
- Beyond Getting Started with Patch Manager
- Patch Manager Getting Started - Additional Resources
- Administer
- Patch Manager Administrator Guide
- Introduction
- Patch Manager Administrator Console
- Configure Patch Manager
- Publish third-party updates
- Push, approve, and install third party updates
- Push the updates
- Approve the updates
- Install the updates using Update Management
- Create PowerShell scripts for third-party updates
- Push the updates with PowerShell scripts
- Schedule the WSUS updates
- Stop an update assigned to the managed systems
- Delete an update assigned to the managed systems
- Check the task history
- Troubleshoot certificate errors during third-party updates
- Uninstall an update from the managed systems
- Uninstall a program using Patch Manager Computer Explorer
- Generate an inventory and create reports
- Manage WSUS using Patch Manager
- Advanced configuration options
- Manage users and security
- Manage client WMI connectivity
- Patch Manager agents
- Integrate Patch Manager with the SolarWinds Platform
- SolarWinds Platform integration architecture
- Access Patch Manager data in the SolarWinds Platform Web Console
- Configure the Patch Manager Web Console
- Access the Patch Manager Summary view
- Generate Patch Manager reports in the SolarWinds Platform Web Console
- Install the Patch Manager Web Console on a separate server
- Administrator functions and settings
- Wake on LAN
- Advanced deployment examples
- Troubleshoot your Patch Manager deployment
- Set up Patch Manager with SCCM
- Integrate Patch Manager with SCCM
- Manage the published third-party updates
- Manage the WSUS servers using the SCCM console
- Provision the WMI Providers using the SCCM console
- Resolve WMI connectivity issues using the SCCM console
- Verify WMI connectivity using the SCCM console
- Troubleshoot Patch Manager in SCCM
- Reference
- Frequently Asked Questions
Use an Application Server role to manage console connections
You can add multiple Application Server roles to manage a large number of console connections. This configuration provides High Availability for your deployment.
To create this configuration, deploy at least three Application server roles:
- Primary Application Server (PAS) where you installed Patch Manager. Patch Manager does not use the PAS for console connections.
- At least two Secondary Application Servers (SAS) to segregate groups of console users and provide a redundancy in case of failure. .
This HA configuration scales to as many Application Server roles as you require. If necessary, each console user could have a dedicated Application Server role for their console connection.
