Latest release: Patch Manager 2025.2
Release Notes
Patch Manager release notes include new features, upgrade notes, fixed and known issues, and end-of-life notices.
Install & Upgrade
Step-by-step instructions and checklists to help you plan, prepare, and then install or upgrade.
Getting Started Guide
Deployment and configuration information to quickly get your new product in place.
Administrator Guide
Beyond the Getting Started Guide, learn how to use all of the features.
Additional Resources
Did you know?
After you create and schedule a task, you can amend the task to include additional updates, such as critical updates. Additionally, if your third party packages fail to download and publish due to web filtering or firewall rules, you can click Retry in the console to reinitiate the procedure.
Take advantage of live and on-demand classes in our Virtual Classrooms.
