Run the SolarWinds Installer in silent mode
Run the SolarWinds Installer or Configuration wizard in silent mode, without displaying the user interface. Adjust the configuration file and run the installer with the /s parameter.
This article applies to SolarWinds Platform products installed with the SolarWinds Installer.
Before you begin
Silent mode means that the installer runs silently, without displaying the user interface.
If you have deployed scalability engines (additional web servers, additional polling engines, or high availability backup servers), upgrade your main SolarWinds Platform server first, and then upgrade your scalability engines.
You can upgrade your product using a properly configured config file.
Centralized Upgrades are available. As long as your scalability engines are reachable, the installer can upgrade all scalability engines from your SolarWinds Platform server in parallel. Upgrade your main SolarWinds Platform server first. If the installer encounters issues with a scalability engine, it will not upgrade that engine but will continue the process and upgrade as many scalability engines as possible. A scalability engine is not upgraded if:
  • The scalability engine is unreachable
  • The preflight check discovers an issue that blocks the upgrade
Before you run the scripts, make sure the SQL Server is installed and accessible from the server where the software is installed.
Known limitations
  • You cannot specify proxy settings in the silent installation mode.
  • You cannot change the installation language in silent mode. When installed using the silent mode, your SolarWinds Platform Web Console is in English.
  • You cannot run the SolarWinds Installer with enabled Windows Defender in silent mode. Windows Defender causes the Configuration Wizard to fail.
Installation overview
To install SolarWinds Platform products in the unattended mode, complete the following steps:
  1. Adjust the configuration file.
  2. Run the silent installation commands to install SolarWinds Platform products or scalability engines.
  3. If you have deployed scalability engines, run the silent installation command to upgrade existing scalability engines.
Step 1: Adjust the configuration file
2024.1 and later
You can generate the configuration file for the silent run by launching the Configuration wizard with a specific parameter. The Configuration wizard collects the custom settings and generates a new SilentConfig.xml file usable for running the Configuration wizard in silent mode.
  1. Launch the Configuration wizard with the -CreateSilentConfig parameter and specify the PATH to save the SilentConfig.xml file in the -cfgOutput parameter.
    Replace the entries in bold red with your data and run the following commands from a command prompt on the main SolarWinds Platform server. The SilentConfig.xml file will be stored in the location you specified.
    cd SW-INSTALL-FOLDER, such as "C:\Program Files (x86)\SolarWinds\Orion"
    ConfigurationWizard.exe -CreateSilentConfig -cfgOutput:PATH
  2. Adjust the config file if necessary.
2023.4.2 and earlier
  1. Review the following configuration examples (XML).
  2. Copy the example that suits your environment and save it.
  3. Adjust the file as needed.
Parameters
Parameters for installing SolarWinds Platform products
The following parameters can be specified in the <InstallerConfiguration> section. Additional parameters can be found in the examples below.
To install EOC, you must download the EOC installer, which is the SolarWinds installer renamed to include -EOC at the end of the file name. The silent installer automatically selects EOC during the installation.
Parameters Values Description
<InstallPath>
Example:
C:\OrionSetup
Specify where you want to install SolarWinds Platform products.
When upgrading, the installation path is reused from the existing installation, and this parameter does not have any effect.
<AdvancedInstallMode> True
True: All information required by the Configuration wizard must be provided in the XML configuration file, including the SQL Server instance details.
False: (For evaluations only.) The installer runs in the Express mode, it installs SQL Express, and runs the Configuration wizard with default configuration values. If you specify the values in the config file, the defaults are overwritten with your input.
Parameters for running the Configuration wizard
Parameters used by the Configuration wizard are specified in the following sections:
<Host>
  <Info>
    <Database>...</Database>
    <Website>...</Website>
  </Info>
</Host>
The following parameters can be specified in the <Info> section, as needed.
<ReconfigureDatabase> True/False Specifies whether the Configuration wizard configures the database.
<ReconfigureWebsite> True/False Specifies whether the Configuration wizard configures the website.
<ReconfigureServices> True/False Specifies whether the Configuration wizard configures services.
<ReconfigurePermissions> True/False Specifies whether the Configuration wizard configures permissions.
<ReconfigureDatabaseConnectionOnly> True/False Specifies whether the Configuration wizard configures only the database connection.
The following parameters can be specified in the <Database> section, as needed. Additional parameters can be found in the examples below.
These parameters should also be specified in the <OrionLogConfiguration> and <NetFlowConfiguration> sections to configure the databases used to store log files and NetFlow data.
<CreateNewDatabase> True/False For upgrades, specify False.
<UseSQLSecurity> True/False
Specify True to authenticate to the database server using SQL Server authentication.
Specify False to authenticate with Windows credentials.
<DatabaseName> string The name of the SolarWinds Platform database.
<ServerName> string A name or IP address to identify the server, such as localhost.
<User> string The SQL Server user name. For a new installation, this user must have the right to create a database.
<UserPassword> string The password of the SQL Server user if UseSQLSecurity is set to True.
<AccountType> NewSql
ExistingSql
ExistingWindows
The type of account used to access the SolarWinds Platform database.
<SqlServerAuthenticationType> WindowsAuthentication
SqlAuthentication
ActiveDirectoryIntegrated
ActiveDirectoryPassword
The type of authentication used to access the SolarWinds Platform database.
<Account> string The name of the SolarWinds Platform database account.
<AccountPassword> string
The password to the SolarWinds Platform database account.
Azure does not support non-secure passwords.
<EncryptConnection> True/False Encrypt the connection to SQL Server with SSL.
<TrustServerCertificate> True/False Skip SQL server certificate validation. Specify for example when self-signed SQL Server connection certificate is used.
The following parameters can be specified in the <Website> section, as needed. Additional parameters can be found in the examples below.
If you have your own certificate, specify CertificateHash, CertificateName, and CertificateResolvableCN in your config.
You can specify only the CertificateResolvableCN property and leave CertificateHash and CertificateName empty. If you do this, the self-signed certificate is generated.
<Folder> string The location of the SolarWinds Platform website folder (for example, C:\InetPub\SolarWinds).
<Port> numeric The SolarWinds Platform website port number.
<EnableHTTPS> True/False If this is set to True, HTTPS will be enabled.
<EnableCentralizedCertificateStore> True/False
If this is set to True, the Centralized Certificate Store will be enabled. Also requires EnableHTTPS to be True.
Ensure that the certificate is valid, not expired, and stored in the Centralized Certificate Store.
<LaunchWebConsole> True/False Specifies whether the SolarWinds Platform Web Console will be launched after the Configuration wizard runs.
<ConfigurationSkipped_IISNotInstalled> True/False If this is set to False and IIS is not installed, it will be installed.
<DefaultAdminPassword> string
The password that the Admin account uses to log in to the SolarWinds Platform Web Console.
For Orion Platform 2019.2 and later, this value can be specified the first time you install a SolarWinds Platform product in a new environment.
If this element is not present and no password is specified for a new installation, the user is prompted to change the password during the first login.
<CertificateHash> string The certificate hash.
<CertificateName> string The certificate name.
<CertificateResolvableCN> string The certificate resolvable common name.
<SkipHTTPBinding> True/False
If this is set to True, IIS website configuration will be skipped.
Set this parameter to False if you want to reconfigure website.
Parameters for installing a scalability engine
If you are installing a scalability engine, specify the following parameters.
<MainPollerHostname>
Example:
1.1.1.1
Specify the IP address or domain name of the main SolarWinds Platform server.
<ServerType>
AdditionalPoller
AdditionalWebsite
MainPoller
Specify the type of scalability engine to be installed.
If MainPollerHostname is not specified, the default value is set to MainPoller.
If MainPollerHostname is specified, the default value is AdditionalPoller.
<IsStandby> True/False
Specify whether the installation should be a High Availability standby server. This applies only when the ServerType is specified as MainPoller or AdditionalPoller. It is false by default.
<WebConsoleUserName> string This value is required when you are installing a scalability engine. It is the user name that the scalability engine can use to connect to the main polling engine.
<WebConsolePassword> string This value is required when you are installing a scalability engine. It is the password that the scalability engine can use to connect to the main polling engine.
Examples
Example A: Standard fresh installation
To provide the SQL Server instance name and/or port, use the following syntax.
<ServerName>hostname\instance,port</ServerName>
The example config is below. Environment-specific values are in RED.
<?xml version="1.0" encoding="utf-8"?>
<SilentConfig>
        <InstallPath>C:\Program Files\SolarWinds\Orion</InstallPath>
        <AdvancedInstallMode>True</AdvancedInstallMode>
        <SkipConfigurationWizardRun>False</SkipConfigurationWizardRun>
        <!--  CW Error handling  -->
    </InstallerConfiguration>
    <Host>
        <Info>
            <ReconfigureDatabase>true</ReconfigureDatabase>
            <ReconfigureWebsite>true</ReconfigureWebsite>
            <ReconfigureServices>true</ReconfigureServices>
            <ReconfigurePermissions>true</ReconfigurePermissions>
            <Database>
                <CreateNewDatabase>true</CreateNewDatabase>
                <!--(Sets flag to create new database during CW)-->
                <UseExistingSqlAccount>False</UseExistingSqlAccount>
                <UseSQLSecurity>true</UseSQLSecurity>
                <!--(Enables SQL Server authentication)-->
                <DatabaseName>SolarWindsOrion</DatabaseName>
                <!--(Orion database name)-->
                <DatabasePath/>
                <ServerName>127.0.0.1</ServerName>
                <!--(SQL server name for silent config wizard, e.g.: localhost)-->
                <InstanceName/>
                <!--(SQL instance name for silent config wizard)-->
                <User>sa</User>
                <!--(SQL account username, when you enabled UseSqlAuthentication)-->
                <UserPassword>Password</UserPassword>
                <!--(SQL account password,  when you enabled UseSqlAuthentication)-->
                <AccountType>NewSql</AccountType>
                <!--(Orion database account access type. Other possible values: ExistingSql, ExistingWindows)-->
                <Account>SolarWindsOrionDatabaseUser</Account>
                <!--(Name of Orion database account, e.g.: SolarwindsOrionDatabaseUser)-->
                <AccountPassword>Password</AccountPassword>
                <!--(Password to Orion database account)-->
                <NeedSQLServerSecurity>false</NeedSQLServerSecurity>
                <NeedToChangeSAPassword>false</NeedToChangeSAPassword>
                <AddServiceDependencies>false</AddServiceDependencies>
                <RemoveServiceDependencies>false</RemoveServiceDependencies>
                <FailureInfo/>
            </Database>
            <Website>
                <Folder>C:\InetPub\SolarWinds</Folder>
                <Address>(All Unassigned)</Address>
                <Port>80</Port>
                <ApplicationName>SolarWinds NetPerfMon</ApplicationName>
                <LaunchWebConsole>false</LaunchWebConsole>
                <ConfigurationSkipped_IISNotInstalled>false</ConfigurationSkipped_IISNotInstalled>
                <EnableWindowsLogin>true</EnableWindowsLogin>
            </Website>
              <StorageConfig>
                <CreateNewDatabase>True</CreateNewDatabase>
                <DatabaseName>SolarWindsOrionLog</DatabaseName>
                <DatabasePath />
                <InstanceName />
                <User>sa</User>
                <SAPassword />
                <FailureInfo />
              </StorageConfig>
            </OrionLogConfiguration>
              <FlowStorageConfig>
                <UseSQLSecurity>True</UseSQLSecurity>
                <DatabaseName>SolarWindsFlowStorage</DatabaseName>
                <DatabasePath />
                <InstanceName />
                <User>sa</User>
                <Account>SolarWindsNtaDatabaseUser</Account>
              </FlowStorageConfig>
            </NetFlowConfiguration>
        </Info>
    </Host>
    <Plugins>
      <Plugin Assembly="SolarWinds.ConfigurationWizard.Plugin.LogMgmt" FactoryType="SolarWinds.ConfigurationWizard.Plugin.LogMgmt.SilentConfigureFactory" />
      <Plugin Assembly="SolarWinds.ConfigurationWizard.Plugin.NetFlow" FactoryType="SolarWinds.ConfigurationWizard.Plugin.NetFlow.SilentMode.NetFlowSilentConfigureFactory" />
    </Plugins>
</SilentConfig>
Example B: Standard fresh installation, configure 443 port
Use the config from Example A, but change the <Website> section to the following. Environment-specific values are in RED.
<Website>
  <Port>443</Port>
  <EnableHTTPS>true</EnableHTTPS>
  <CertificateHash>environment specific</CertificateHash>
  <CertificateName>environment specific</CertificateName>
  <CertificateResolvableCN>environment specific</CertificateResolvableCN>
</Website>
Example C: Configuration files for installing scalability engines
Configuration file for installing SolarWinds High Availability when using Windows Authentication
This example installs SolarWinds High Availability when using Windows Authentication. Windows Authentication requires you to set a few more options. Environment-specific values are in RED.
<SilentConfig>
        <MainPollerHostname>1.1.1.1</MainPollerHostname>
        <ServerType>MainPoller</ServerType>
        <IsStandby>True</IsStandby>
        <WebConsoleUserName>Admin</WebConsoleUserName>
        <!--Enter user name and password only for first installation of SE.-->
        <WebConsolePassword>Password</WebConsolePassword>
    <Host>
        <Info>
            <Database>
                <AccountType>ExistingWindows</AccountType>
                <SqlServerAuthenticationType>WindowsAuthentication</SqlServerAuthenticationType>
            </Database>
        </Info>
    </Host>
</SilentConfig>
Configuration file for installing an additional website
This example installs an additional website. Environment-specific values are in RED.
<SilentConfig>
        <ServerType>AdditionalWebsite</ServerType>
        <IsStandby>false</IsStandby>
</SilentConfig>
Example D: Upgrades
The following examples upgrade your product to a newer version.
You can use a shortened version of the config (below) if you don't want to change anything. During the upgrade, all required values are taken from the registry.
<SilentConfig>
  <Host>
    <Info>
    </Info>
  </Host>
  <Plugins>
  </Plugins>
</SilentConfig>
If you want to reconfigure certain databases or a website, include in the config only those sections that are related to the element you want to reconfigure.
The following example reconfigures the website to use port 443 and the NetFlow database. Environment-specific values are in RED.
<SilentConfig>
    <Host>
        <Info>
            <Website>
                <Port>443</Port>
                <SkipHTTPBinding>false</SkipHTTPBinding>
            </Website>
              <FlowStorageConfig>
                <CreateNewDatabase>False</CreateNewDatabase>
                <UseExistingSqlAccount>True</UseExistingSqlAccount>
                <DatabasePath />
                <InstanceName />
                <User>sa</User>
                <AccountType>ExistingSql</AccountType>
        </Info>
    </Host>
    <Plugins>
    </Plugins>
</SilentConfig>
The following upgrade examples use a full config. Environment-specific values are in RED.
<SilentConfig>
    <Host>
        <Info>
            <Database>
                <DatabasePath/>
                <InstanceName/>
                <User>sa</User>
                <SAPassword>Password</SAPassword>
                <FailureInfo/>
            </Database>
            <Website>
                <Port>443</Port>
            </Website>
              <StorageConfig>
                <DatabasePath />
                <InstanceName />
                <User>sa</User>
                <SAPassword />
                <FailureInfo />
              </StorageConfig>
              <FlowStorageConfig>
                <DatabasePath />
                <InstanceName />
                <User>sa</User>
        </Info>
    </Host>
    <Plugins>
    </Plugins>
</SilentConfig>
Example E: Database connection only
This example uses SQL Authentication. If Windows authentication is needed, additional settings will need to be switched from true to false or visa versa. Environment-specific values are in RED.
d<?xml version="1.0" encoding="utf-8"?>
<SilentConfig>
  <Host>
    <Info>
      <ReconfigureDatabase>false</ReconfigureDatabase>
      <ReconfigureWebsite>false</ReconfigureWebsite>
      <ReconfigureServices>false</ReconfigureServices>
      <ReconfigurePermissions>false</ReconfigurePermissions>
      <ReconfigureDatabaseConnectionOnly>true</ReconfigureDatabaseConnectionOnly>
      <Database>
        <CreateNewDatabase>false</CreateNewDatabase>
        <DatabasePath />
        <User>SolarWindsOrionDatabaseUser</User>
        <SqlServerAuthenticationType>SqlAuthentication</SqlServerAuthenticationType>
      </Database>
        <FlowStorageConfig>
          <ForceSimpleEvalMode>false</ForceSimpleEvalMode>
          <UseSQLSecurity>false</UseSQLSecurity>
          <EncryptConnection>false</EncryptConnection>
          <TrustServerCertificate>false</TrustServerCertificate>
          <InstanceName>SOLARWINDS_ORION</InstanceName>
          <PreserveInstanceName>false</PreserveInstanceName>
        <StorageConfig>
          <SAPassword />
        </StorageConfig>
    </Info>
  </Host>
  <Plugins>
  </Plugins>
</SilentConfig>
Step 2: Run the silent installation commands
Install or upgrade
If you are running an installation or upgrade, replace the entries in bold red with your data, and run the following commands using the command prompt.
The /s flag makes the installer run in silent mode. You might need to add "" before /wait: ""/wait
cd "FOLDER-WHERE-INSTALLER-IS"
start /wait "PRODUCT-INSTALLER-EXE" /s /ConfigFile="FULL-PATH-TO-CONFIGURATION-FILE"
You must use the full path to the configuration file, not a relative path, for the command to work properly.
Skip validation of the configuration file
Starting with 2023.4, a simple validation of the config is run by default. However, the validation does not guarantee that the configuration is correct. You can find the output in the logs. You can skip the validation by adding the SkipValidation argument:
start /wait "PRODUCT-INSTALLER-EXE" /s /ConfigFile="FULL-PATH-TO-CONFIGURATION-FILE" /SkipValidation
Reconfigure an existing deployment
If you are reconfiguring an existing deployment without a fresh installation or upgrade, replace the entries in bold red with your data, and run the following commands using the command prompt.
These scenarios include updating the database connection or website settings.
cd C:\Program Files\SolarWinds\Orion
ConfigurationWizard.exe -silent -cfg:'C:\Temp\SilentConfig.xml'
Optionally, you can tail the ConfigurationWizard.log file to see progress. Since the -silent flag is used there will not be anything shown on screen.
PowerShell example
Update the path accordingly if your installation is located if a different directory from default.
Get-Content -Path C:\ProgramData\SolarWinds\logs\Orion\ConfigurationWizard.log -Tail 20 -wait
Step 3: Run the silent installation command to upgrade existing scalability engines
Install or upgrade
If you are running an installation or upgrading products in an existing deployment that includes scalability engines, you can run a Centralized Upgrade in silent mode after the main polling engine is upgraded. The Centralized Upgrade does the following:
  1. Contacts all reachable scalability engines and performs preflight checks.
    If any scalability engine is not reachable or has a blocking issue, the issue is logged and that scalability engine is not upgraded.
  2. Downloads the installer to each scalability engine without blocking issues, and runs the installers in parallel.
  • The silent centralized upgrade requires the main polling engine to be updated so that the user can update outdated scalability engines to the main polling engine version.
  • Do not stop the SolarWinds Administration Service on your scalability engines before the centralized upgrade. If you stop this service, the scalability engines are not reachable.
To start the Centralized Upgrade, replace the entries in bold red with your data, and run the following commands from a command prompt on the main SolarWinds Platform server.
start "PRODUCT-INSTALLER-EXE" /silentcentralizedupgrade
As the upgrade progresses, you can track progress from the SolarWinds Platform Web Console.
Reconfigure existing deployment
If you are reconfiguring an existing deployment without a fresh installation or upgrade, no further steps are required.
