SolarWinds Platform Products Installation and Upgrade Guide
Use the SolarWinds Installer to install and upgrade SolarWinds Platform or Orion Platform products. With one installer, you can install or upgrade multiple products. You can also install or upgrade scalability engines (additional polling engines, additional web servers, and high availability servers).
If you’re installing SolarWinds Enterprise Operations Console (EOC), it must be installed on its own server. To install or upgrade EOC, download the appropriate installer and follow the instructions for the SolarWinds Installer. The installer automatically installs or upgrades EOC based on your licensing.
Find out whether you need to migrate deployed products or deployed database and how to do it.
