Quality of Experience requirements
Before you deploy a Packet Analysis Sensor to a device to monitor QoE, review the following minimum system requirements.
You will need administrative privileges for each node or switch.
Sensors cannot be installed on 32-bit computers and do not support communication over https.
Network Packet Analysis Sensors (NPAS)
| hardware/ software |
requirements | |
| OS |
| CPU Cores | 2 CPU Cores + 1 CPU Core per 100 Mbps | |
| Hard drive space | 500 MB | |
| Memory | 1 GB + 1 GB per 100 Mbps (2 GB + 1 GB per 100 Mbps recommended) |
| Network | 1Gbps maximum throughput | |
| Port monitoring |
For a physical monitored switch:
For a virtual monitored switch:
Port monitoring requires at least one extra network interface to collect data from the managed network interface, a server to monitor the copied traffic, and a network cable to connect the mirrored port to the physical server. View your vendor documentation for instructions about how to set up port mirroring. You can create port mirrors for both physical switches and virtual switches. |
Server Packet Analysis Sensors (SPAS)
requirements |
OS |
CPU Cores |
Hard drive space |
500 MB |
Memory |
256 MB + 500 MB per 100 Mbps (256 MB recommended + 500 MB per 100 Mbps) |
Network |
Target computer port requirements
| Port | Protocol | Service/ Process |
Direction | Communi-cation method |
Description |
135 |
TCP |
Agent installer |
Inbound |
Either | (DCE/RPC Locator service) Microsoft EPMAP. This port must be open on the target computer for remote deployment. |
445 |
TCP | Agent installer |
Inbound |
Either | Microsoft-DS SMB file sharing. This port must be open on the client computer (inbound) for remote deployment. |
| 17778 |
TCP |
SolarWinds Agent |
Outbound |
Agent-initiated | Used continuously by the agent to communicate back to the SolarWinds Platform server. Also used to deploy the agent. |
17790 |
TCP |
SolarWinds Agent |
Inbound |
Server-initiated | Used to communicate with the SolarWinds Platform server. |
