View firmware vulnerability and risk information in SolarWinds Observability Self-Hosted Advanced
Firmware vulnerabilities are a serious threat to network security. SolarWinds Observability Self-Hosted helps you mitigate the risk by identifying nodes that are potentially affected by known vulnerabilities. Firmware vulnerability data is imported from the National Vulnerability Database (NVD), which is maintained by the National Institute of Standards and Technology (NIST). SolarWinds Observability Self-Hosted then correlates this vulnerability data with nodes that it currently manages.
To provide a more accurate and context‑aware assessment of real‑world risk, the platform also incorporates EPSS (Exploit Prediction Scoring System) data into its vulnerability evaluation. EPSS offers a data‑driven estimate of the likelihood that a vulnerability will be exploited in the wild. By including EPSS in the overall Risk Score for systems and individual nodes, the platform adjusts prioritization based not only on severity (CVSS) and asset context but also on the probability of exploitation. This helps reduce noise, strengthen decision‑making, and ensure that remediation efforts focus on the vulnerabilities that pose the greatest operational risk.
Vulnerabilities must have a status of Enriched before SolarWinds Observability Self-Hosted can import the associated data. Vulnerabilities with an earlier status (such as Awaiting Enrichment) are not detected. For more information about NVD statuses, see this page.
See the following sections:
Device types
If you have a SolarWinds Observability Self-Hosted Advanced license, potential vulnerabilities are detected in the following device types:
  • Aerohive/Extreme Networks HiveAP 20
  • APC NetBotz devices
  • Axis Communications devices and cameras
  • Cisco IOS, Cisco IOS XE, IOS XR, Cisco Adaptive Security Appliance (ASA), and Cisco Nexus
  • Cisco Meraki
    • Cisco Meraki MX
    • Cisco Meraki MS
    • Cisco Meraki MR
    • Cisco Meraki CS
  • Dell DRAC and iDRAC
  • Fortinet FortiGate nodes running on FortiOS
  • HPE Aruba:
    • AOS-CX switches OS version 15.xx.xxxx-16.xx.xxxx
    • AOS-S switches OS version 10.xx.xxxx
    • ArubaOS switches (SysObjectID starts with 1.3.6.1.4.1.14823.1.1)
  • Huawei VRP
  • Juniper
  • Linux: Ubuntu OS
  • Palo Alto firewall devices running on PAN-OS
  • Red Hat Enterprise Linux
  • VMWare ESXi versions 6.0, 6.5, 6.7, 7.0, and 8.0
  • VMWare vCenter versions 6.0, 6.5, 6.7, 7.0, and 8.0
  • Windows
  • Windows Hyper-V Server
The firmware vulnerability feature is disabled by default. If necessary, you can enable or disable this feature or change other settings.
Get an overview of the risk from current firmware vulnerabilities
Use the Vulnerability and Risk Dashboard to find out how many nodes are currently threatened by potential vulnerabilities, how serious those vulnerabilities are, and the level of risk for your network.
To open the dashboard, click My Dashboards > Security > Vulnerability and Risk Dashboard.
The Vulnerability and Risk Dashboard displays the following widgets by default.
You can customize a dashboard to add widgets.
Node Count by Vulnerability widget
The Node Count by Vulnerability widget displays:
  • The total number of nodes matched to at least one CVE.
  • The number of nodes matched to a CVE with a critical severity score (9 or higher).
  • The number of nodes matched to a CVE with a high severity score (7 or higher but less than nine).
Vulnerability Count by Severity widget
The Vulnerability Count by Severity widget displays the total number of discovered CVEs in a system and a count of vulnerabilities by severity (Critical, High, Medium, Low, None).
Risk Score widget
The risk score is a visual indication of the level of risk for your network based on the number of CVEs for all nodes and the severity of each CVE.
Top 100 Vulnerabilities widget
The Top 100 Vulnerabilities widget lists CVEs with the highest severity scores that were detected on monitored nodes. It also shows the CVE severity score, EPSS, and the number of nodes it affects.
Vulnerability Count by OS widget
The Vulnerability Count by OS widget shows a bar graph that represents the number of CVEs found on nodes with each type of operating system.
All Nodes widget
The All Nodes widget lists all monitored nodes and displays the total number of CVEs found for a node and the number of CVEs by severity. Use the Search box at the top to find a specific node.
View additional information on detail pages
List of Nodes page
To open the List of Nodes page, click from any of these widgets:
This page provides information about each node, including a node health indicator, the risk score for the node, and the number of active CVEs by severity matched to the node.
To find a node:
  • In the left pane, apply filters to display a subset of the nodes.
  • Enter a string in the Search box above the table to show only nodes whose name, OS, or release includes that string.
List of Vulnerabilities page
To open the List of Vulnerabilities page, click from any of these widgets:
Click a severity on the Vulnerability Count by Severity widget to open this page and automatically filter by that severity.
This page includes a row for each discovered vulnerability on every node it was matched to. The information includes severity, EPSS, and the current state of each vulnerability. You can change the state of one or more vulnerabilities.
To find a vulnerability:
  • In the left pane, apply filters to display a subset of the CVEs.
  • Enter a string in the Search box above the table to show only rows with that string in the CVE, Node, or OS column.
Click a CVE ID to open the Vulnerability Summary page. Click a node name to open the Node Details page.
To open the Vulnerability Summary page, click the CVE ID on the Top 100 Vulnerabilities widget or the List of Vulnerabilities page.
This page displays detailed information about the selected CVE, with a link to the NVD vulnerability details page on the NIST website or EPSS. It also lists the nodes that are potentially affected by this vulnerability, as well as the current state of each vulnerability. You can change the state of one or more vulnerabilities.
Change the state of a vulnerability on a node
Set the state of a firmware vulnerability on a node to track remediation efforts. You can also set the state to indicate that the vulnerability does not apply to that node.
  1. Locate the vulnerabilities:
    • Open the List of Vulnerabilities page, and apply filters or use the search bar to display only the rows whose state you want to change.
      For example, to update the state of CVE-2026-1234 on all Cisco devices:
      • Under OS, apply the Cisco filter.
      • Under Vulnerability, apply the CVE-2026-5678 filter.
    • Open the Vulnerability Summary page to display a list of potentially affected nodes.
  2. Select the checkbox in the left column for each row whose vulnerability state you want to change. To select all currently displayed rows, select the checkbox in the table header.
    When one or more rows is selected, the Change State option is displayed above the table.
  3. Click Change State.
    The Change Node CVE States dialog opens.
  4. Under State, select the state that reflects the current remediation status:
    State Description
    Potential vulnerability The vulnerability has not yet been verified. (This is the default.)
    Confirmed vulnerability The vulnerability is confirmed but no remediation is planned.
    Not applicable The vulnerability does not affect or cannot be exploited on the selected nodes.
    Remediation planned Action to remediate the threat is planned but has not been taken.
    Remediated The vulnerability is confirmed and action to remediate the threat has been taken on the selected nodes.
    Waiver A waiver has been issued to exempt the selected nodes from remediation.
  5. Optionally, add a comment to record findings, plans, or completed actions.
  6. Click Change.
View information about state changes
Click the value in the State column on the List of Vulnerabilities page or the Vulnerability Summary page to open the Change State Details dialog. This dialog displays the date and time of the most recent state change, as well as any comments.
Configure who can view security information
By default, only the default Admin user can see security information. To enable other users to access security dashboards and widgets, assign them the Administrator role under Security Settings.
  1. In the web console, click Settings > All Settings.
  2. Click Manage Accounts.
  3. Create a new account, or select an existing user account and click Edit.
  4. On the Edit User Account page, scroll down and expand Security Settings.
  5. Select Administrator and submit your changes.
Security roles overview
Security roles are specific to the Security feature and are independent of global SolarWinds Platform user roles.
Administrator
Grants full access to the Security feature.
The default ‘Admin’ account is assigned this role.
During upgrades, all accounts with Administrator privileges are automatically assigned this role.
Users with this role can access all dashboards, pages, and configuration settings under Product Specific Settings > Security Settings. These include:
  • Security Dashboards
  • List of Nodes page
  • List of Vulnerabilities page
  • Vulnerability Details pages
Users with the Administrator security role can change the state of vulnerabilities on the List of Vulnerabilities and Vulnerability Details pages.
User
Provides read-only access to all security dashboards and pages.
Does not allow access to Security settings, such as:
  • Access Rights Manager Settings
  • Security Event Manager Settings
  • CVE Data Import Settings
  • CVE Node Matching Settings
Users with this role cannot change the state of vulnerabilities, they can only view them.
None
No access to the Security feature.
Users with this role cannot work with Security dashboards, they have no access to pages such as List of Nodes, List of Vulnerabilities, or Vulnerability details.
This is the default role assigned to all new accounts. It's also applied to existing accounts without Administrator privileges after upgrading to a version that includes the security roles.
Configure EPSS data source and synchronization
EPSS scores are obtained from the official EPSS dataset and synchronized through a secure, dedicated proxy service. The proxy retrieves the latest available scores and supplies them to the platform for use in risk calculations.
By default, EPSS is included in system score calculations.
Change the source file for EPSS data (offline systems)
  1. In the SolarWinds Platform Web Console, click Settings > All Settings.
  2. Under Product-specific settings, click Security Settings.
  3. Under Vulnerabilities, click CVE Data Import Settings.
  4. Update the path to the EPSS archive as needed.
    If you are in an offline environment:
    1. Copy the default URL from the EPSS File field and download the file.
    2. Save the file in your offline environment and ensure the file name is epss_scores.zip.
    3. Enter the path to the file in the EPSS File field.
  5. Submit your changes.
EPSS data is now included into system score calculations.
Manage EPSS data in risk score calculations
  3. Under Vulnerabilities, click CVE Node Matching Settings.
  4. Enable or disable EPSS data usage for risk score calculation using the Score Calculation Settings toggle.
Risk scores are recalculated.
