Docker Swarm requirements, deployment command examples, and container removal steps
SAM — VMAN
Docker Swarm is one of the environments supported by the Container Monitoring feature.
To monitor Docker Swarm containers in the SolarWinds Platform, you'll need:
  • Docker Engine 17.12 or later
  • Docker Compose file format 3.5 or later
  • SSH access to the master server
  • Sudo privileges on the master server
    IPv6-enabled environments are not supported for monitoring of Docker, Docker Swarm, or Apache Mesos containers.
Required ports include:
  • 4043: Container port (internal Docker communication).
  • 6784: Report/wave status (internal Docker communication).
  • 80: Used to download the configuration file from the SolarWinds Platform server.
    An alternative to using port 80 is to download the file manually and send it to the Docker host.
Container monitoring image
The new Docker probe is now packaged together with the Kubernetes probe into a single unified image: solarwinds/cman:latest. The image with the latest tag is updated to include the latest security fixes. You can find it under: https://hub.docker.com/r/solarwinds/cman/tags.
Docker Swarm installation commands
When you add a container service, the Manage Container Service wizard generates commands that you can copy to the Windows Clipboard. Connect to the master server via SSH, open a command line, and run commands to:
  • Download a cman-swarm.yaml file,
  • Set the hostname in the file to the master server, and
  • Start a service named "sw" to deploy an sw_orionmonitor container to each server in the swarm.
Delete Docker Swarm containers and container images from nodes
Before you delete a container service in the SolarWinds Platform Web Console, remove Orion containers and images from the nodes (or cluster of nodes) manually.
  1. Connect to the node via SSH.
  2. Run the following commands to remove the sw_orionaggregator and sw_orionmonitor containers:
    sudo docker service rm sw_orionaggregator
    sudo docker service rm sw_orionmonitor
  3. Run the following command to get a list of images and note the IDs for docker.dev.local/scope2orion and weaveworks/scope:latest.
    sudo docker images
  4. Run the following command for each image:
    sudo docker rmi [image_id]
  5. Remove secrets associated with the images:
    docker rm sw_scope_password sw_solarwinds_token
The service status switches to Down on the Container Services page. Now you can delete the container service by selecting its check box and clicking Delete.
