Azure Monitor cloud metric reference
IPAM — NAM — NPM — SAM — VMAN
This table details metrics available for Azure VMs and volumes.
You may notice that more metrics appear for AWS instances than for Azure volumes. This is due to the fact that AWS generally provides more metrics for volumes than Azure does, as reflected by the metrics displayed in the SolarWinds Platform Web Console.
Category Metric
Response Response Time
Wait Time Instance Wait TIme
Session
Active Sessions
Total User Sessions
Blocked Sessions
Distinct Machines
Distinct Users
Resources
CPU Utilization
Memory Utilization
I/O Stats
Total Read I/O Wait
Total Write I/O Wait
Total I/O Wait
SQL Disk Read Latency
SQL Disk Write Latency
Performance Counters
Transaction Rate
Buffer Cache Hit Ratio
Procedure Cache Hit Ratio
Batch Requests per Second
SQL Compilations per Second
SQL Re-compilations per Second
Log Bytes Flushed per Second
Log Flushes per Second
Buffer Cache Size
Page Life Expectancy
Page Read per Second
Page Write per Second
Plan Cache Size
CPU Queue Length
Memory Paging Rate
Physical I/O Rate
Physical Read Rate
Physical Write Rate
Disk Queue Length
Azure VM backup status metrics (only when monitoring feature is enabled)
Backup Enabled
Last Backup Status
Last Backup Poll
Miscellaneous CPU Count
Disk Queue Length
Instance CPU Utilization
Signal Waits Percentage
