- Release Notes
- SolarWinds Observability Self-Hosted 2025.1.1 release notes
- SolarWinds Observability Self-Hosted 2025.1 release notes
- SolarWinds Observability Self-Hosted 2024.4.1 release notes
- SolarWinds Observability Self-Hosted 2024.4 release notes
- SolarWinds Observability Self-Hosted 2024.2.1 release notes
- SolarWinds Observability Self-Hosted 2024.2 release notes
- SolarWinds Observability Self-Hosted 2024.1.1 release notes
- SolarWinds Observability Self-Hosted 2024.1 release notes
- SolarWinds Observability Self-Hosted 2023.4.2 release notes
- SolarWinds Observability Self-Hosted 2023.4.1 release notes
- SolarWinds Observability Self-Hosted 2023.4 release notes
- SolarWinds Observability Self-Hosted 2023.3.1 release notes
- SolarWinds Observability Self-Hosted 2023.3 release notes
- SolarWinds Observability Self-Hosted 2023.2.2 release notes
- SolarWinds Observability Self-Hosted 2023.2.1 release notes
- SolarWinds Observability Self-Hosted 2023.2 release notes
- SolarWinds Observability Self-Hosted 2023.1.1 release notes
- SolarWinds Observability Self-Hosted 2023.1 release notes
- SolarWinds Observability Self-Hosted 2022.4.1 release notes
- SolarWinds Observability Self-Hosted 2022.4 release notes
- SolarWinds Observability Self-Hosted release history
- SolarWinds Platform release history
- SolarWinds Platform release notes aggregator
- Install or Upgrade
- SolarWinds Platform Products Installation and Upgrade Guide
- About installing or upgrading SolarWinds Platform products and scalability engines
- Prepare to install or upgrade SolarWinds Platform products
- Install SolarWinds Platform products in a new environment
- Install an additional polling engine, additional web server, or HA server in a SolarWinds Platform deployment
- Options for upgrading scalability engines
- Upgrade an existing deployment
- Add a new SolarWinds Platform product to an existing deployment
- Troubleshoot a SolarWinds Platform product installation
- Scalability engine guidelines for SolarWinds products
- Deploy SolarWinds Platform products to Amazon Web Services
- Deploy SolarWinds Platform products to Microsoft Azure
- Install SolarWinds Platform products using Azure Marketplace in Microsoft Azure or Microsoft Azure Government
- Install SolarWinds Platform products using Amazon AWS Marketplace (CloudFormation)
- Deploy the SolarWinds Platform in a multi-tenant way
- Run the SolarWinds Installer in silent mode
- Reasons to Upgrade SolarWinds Platform Products from a 2012 Infrastructure
- SolarWinds Platform Migration Guide
- Migrate the SolarWinds Platform server with minimal downtime
- Migrate SolarWinds Platform products to a new server using the same IP and hostname
- Migrate SolarWinds Platform products to a new server with a new IP or hostname
- Migrate the SolarWinds Platform database to a new server
- Migrate the SolarWinds Platform database to or from a Microsoft Azure database solution
- Migrate the SolarWinds Platform database to Amazon RDS for SQL Server
- Upgrade the Orion SQL Server without migration
- Get Started
- Administer
- SolarWinds Observability Self-Hosted and SolarWinds Platform Administrator Guide
- SolarWinds Platform features
- What is SolarWinds Observability and how does it work
- Licensing model for SolarWinds Observability Self-Hosted
- SolarWinds Observability Self-Hosted licensing model
- License SolarWinds Platform products in the SolarWinds Platform Web Console
- Evaluate SolarWinds Platform products
- Activate your SolarWinds Observability Self-Hosted license
- Activate licenses for SolarWinds Platform products
- Upgrade licenses in the SolarWinds Platform
- Assign licenses for SolarWinds Platform products to a server
- Migrate SolarWinds Platform licenses from one server to another
- Synchronize licenses in the SolarWinds Platform
- Connect SolarWinds Observability Self-Hosted to SolarWinds Observability SaaS
- Anomaly-Based Alerting in SolarWinds Observability Self-Hosted
- View and manage security data
- Discover and add network devices to SolarWinds Platform
- Discover your network for the SolarWinds Platform with the Discovery Wizard
- Add nodes to SolarWinds Platform using Active Directory
- Credentials for Active Directory discovery in SolarWinds Platform
- Automatically add discovered nodes to SolarWinds Platform
- Advanced discovery in the SolarWinds Platform
- Add discovered devices to the SolarWinds Platform
- Add a single node for monitoring to the SolarWinds Platform
- Choose the polling method to use in the SolarWinds Platform
- Use a list of IP addresses to discover your network
- Manage scheduled discovery results in the SolarWinds Platform
- Set the default SNMP version for wizards
- Minimize SNMP processing load during discoveries in the SolarWinds Platform using the Discovery Ignore List
- Manage devices in the SolarWinds Platform Web Console
- Delete devices from monitoring
- View node data in tooltips
- Edit node properties
- Change the polling method for a node
- Promote a node from ICMP to SNMP monitoring
- Change polling engine node assignments in the SolarWinds Platform
- View the resources and statistics monitored on a node
- Monitor volumes in the SolarWinds Platform
- Suspend data collection or alerts for nodes in Maintenance Mode
- Poll and rediscover devices immediately
- Calculate node status in the SolarWinds Platform
- Node status contributors
- Status Rollup Mode in the SolarWinds Platform
- Group objects and mirror network dependencies in the SolarWinds Platform Web Console
- View events, alerts, traps, and syslogs in the SolarWinds Platform Web Console Message Center
- Monitor hardware health
- Monitor Hardware Health for Nutanix clusters
- Nutanix Hardware Health monitoring requirements
- Set up Hardware Health monitoring for Nutanix clusters
- Display Hardware Health data for Nutanix clusters
- Understand Nutanix sensor status mapping
- Manage alerts and reports for Nutanix clusters
- Troubleshoot Nutanix Hardware Health monitoring
- Monitor Cisco UCS devices in the SolarWinds Platform
- Monitor cloud instances and VMs
- Recommendations and requirements for monitoring cloud accounts
- Configure cloud accounts for the SolarWinds Platform
- Find cloud account credentials
- Add the first cloud account to the SolarWinds Platform
- Explore cloud instances and VMs
- Cloud service polling overview
- Throttling overview: control resources used by your cloud instance/VM
- Manage your cloud infrastructure
- Monitor containers in the SolarWinds Platform
- Monitor virtual infrastructure
- Quality of Experience
- Monitor Quality of Experience metrics
- Poll devices with SolarWinds Platform Agents
- View logs and events with the Log Viewer
- Alert Integrations in the SolarWinds Platform
- Troubleshooting environmental issues with Performance Analysis dashboards
- Use alerts to monitor your environment with the SolarWinds Platform
- Alert preconfiguration tasks in the SolarWinds Platform
- Configure the default information in the email action for SolarWinds Platform alerts
- Best practices and tips for alerting in the SolarWinds Platform
- Navigate to the Alert Manager in the SolarWinds Platform
- Add an SMTP server in the SolarWinds Platform
- Create new alerts to monitor your environment with the SolarWinds Platform
- Reduce alerting noise in the SolarWinds Platform
- Commonly created alerts in the SolarWinds Platform
- View triggered SolarWinds Platform alerts in the SolarWinds Platform Web Console
- Remove alerts from the Active Alerts list in the SolarWinds Platform
- Test alert triggers and actions in the SolarWinds Platform
- Modify multiple alerts or share alerts in the SolarWinds Platform
- Build complex conditions in the SolarWinds Platform
- Manage alert actions in the SolarWinds Platform
- Approve alert actions executing a script
- Alert actions available in the SolarWinds Platform
- Variables in the SolarWinds Platform
- Changes in the alerting engine introduced in Orion Platform 2015.1
- Alert migration to the web
- Share SolarWinds Platform alerts with other SolarWinds products
- AlertStack
- Manage SolarWinds Platform Web Console user accounts in the SolarWinds Platform
- Create users in the SolarWinds Platform
- Change passwords for SolarWinds Platform users
- Unlock user accounts
- Set and manage user account expiration
- Configure user password expiration
- Enable SolarWinds Platform users to authenticate through LDAP
- Authenticate SolarWinds Platform users with SAML v2
- Define what users can access and do in the SolarWinds Platform
- Restrict user access to network areas by applying limitations in the SolarWinds Platform
- Set default menu bars and views for users in the SolarWinds Platform
- Limit users to specific network areas in the SolarWinds Platform
- Configure automatic login in the SolarWinds Platform
- Manage polling engines in the SolarWinds Platform
- Additional Polling Engines in the SolarWinds Platform
- Use an Additional Web Server
- Calculate node availability in the SolarWinds Platform
- Assign credentials to virtual servers in the SolarWinds Platform
- Set the node warning level in the SolarWinds Platform
- Delete polling engines in the SolarWinds Platform
- Administrative functions of the SolarWinds Platform Web Console in the SolarWinds Platform
- SolarWinds Platform Web Console administration in the SolarWinds Platform
- View secure data in the SolarWinds Platform
- Handle counter rollovers in the SolarWinds Platform
- Configure web proxy settings in the SolarWinds Platform
- Maintain the SolarWinds Platform database in the SolarWinds Platform
- Security enhancements and exceptions for SolarWinds Platform products
- Update polling settings in the SolarWinds Platform
- Manage the SolarWinds Platform Web Console for your SolarWinds Platform
- Customize the SolarWinds Platform Web Console look, views, settings, charts, and maps in the SolarWinds Platform
- Customize the SolarWinds Platform Web Console look for the SolarWinds Platform
- Add custom properties to node popovers in the SolarWinds Platform
- Dashboards or views
- How custom views/classic dashboards work in the SolarWinds Platform
- SolarWinds Platform Web Console and chart settings for the SolarWinds Platform
- Customize charts in the SolarWinds Platform Web Console for the SolarWinds Platform
- Customize modern dashboards
- Intelligent Maps for SolarWinds Platform products
- Define what users can access and do in Intelligent Maps
- View details for SolarWinds Platform entities on Intelligent Maps
- Work with entities in auto-generated Intelligent Maps in the Map subview
- Adjust auto-generated Intelligent Maps in the SolarWinds Platform
- Understand connections on Intelligent Maps in the SolarWinds Platform
- Create and edit Intelligent Maps
- Clone Intelligent Maps
- Create nested maps in Intelligent Maps
- Create wireless heat maps with Intelligent Maps
- Import maps
- Add Intelligent Maps to views as a widget
- Use Intelligent Maps in alerts and reports
- Use Intelligent Maps to view historical events
- View monitored objects on Worldwide map or on Network Atlas maps in the SolarWinds Platform
- Manage and view reports in the SolarWinds Platform
- Predefined reports in the SolarWinds Platform
- Modify an existing web-based report for the SolarWinds Platform
- Create a web-based report in the SolarWinds Platform
- Add content to a web-based report in the SolarWinds Platform
- Customize a chart for SolarWinds Platform reports
- Customize a table for web-based reports
- Customize a web-based report layout in the SolarWinds Platform
- Restrict who can access reports in the SolarWinds Platform
- Generate reports in the SolarWinds Platform on a schedule
- Export and import reports in the SolarWinds Platform
- Troubleshoot reports
- Create custom monitors in the SolarWinds Platform
- Access nodes using HTTP, SSH, and Telnet in the SolarWinds Platform
- Optimize and scale SolarWinds Platform products
- Troubleshoot Orion Deployment issues with Active Diagnostics
- Know the environment monitored with the SolarWinds Platform
- What devices to monitor with SolarWinds Platform and what do you need to know about them?
- Optimize polling engines in your SolarWinds Platform deployment
- Optimize the database used by SolarWinds Platform products
- Optimize the performance of the SolarWinds Platform Web Console
- Don't forget about maintaining your SolarWinds Platform deployment
- Collect diagnostics from the SolarWinds Platform Web Console
- Secure Configuration for the SolarWinds Platform
- URLs to allow-list in firewalls to enable in SolarWinds Platform
- SolarWinds Platform features affected by Internet access
- SQL Server configuration best practices for SolarWinds Platform products
- High Availability in SolarWinds Platform products
- Disaster recovery in the SolarWinds Platform
- How failovers work
- When do I use a VIP or a virtual hostname?
- Which IP address is used as the source when using a VIP?
- SolarWinds Platform High Availability requirements
- SolarWinds Platform High Availability deployment walk-through
- Disable or delete HA pools, force a failover, or update an HA pool for SolarWinds Platform products
- Critical third-party software components in SolarWinds Platform
- SolarWinds approach to comprehensive Exchange monitoring
Set a floor plan as the background for visualizing wireless coverage in NPM
NPM
The floor plan should reflect the real dispositions of the office or buildings on the map, so that you can correctly position the wireless access points and reflect the wireless signal coverage on your map.
Requirements:
The floor plan must be a graphic file in one of the following graphics formats:
- Graphics Interchange Format (.gif, non-animated)
- Tagged Image File Format (.tiff)
- Joint Photographic Experts Group (.jpg)
- Microsoft Windows Bitmap (.bmp)
- Portable Network Graphics (.png)
To ensure the readability of wireless heat maps, use black and white images.
To set a background for wireless heat maps:
- Create the wireless heat map in the Network Atlas.
- Click Background Image on the Home ribbon.
- Navigate to the floor plan image, select the image, and click Open.
The floor plan will appear as the background for your heat map.
