Documentation forSecurity Event Manager
Install a node-level SEM agent running in Kubernetes as DaemonSet
This section describes how to monitor your kubernetes (K8s) cluster containers in the SEM Console using a node-level agent running as DaemonSet.
See the Kubernetes website located at https://kubernetes.io for information about DaemonSet and the Kubernetes open-source platform. See the Docker website located at https://docker.com for information about the Docker open-source platform. See Add or edit Kubernetes API logs connector for information about the Kubernetes API logs collector.
The procedures in this section do not focus on collecting logs to a single file.
Node-level agent example
The following diagram illustrates how the node-level agent collects and transfers the container logs to the SEM manager.
In this example, the following procedures occur:
  1. The App container pushes all non-persistent logs to STDOUT (standard output).
  2. The log collecting container collects and writes the logs to the persistent file on the node.
  3. The node-level agent running in the pod collects the recorded logs from the file.
  4. When the log collection process is completed, the agent sends the logs to the SEM manager.
Required files
Create the following files in the same location:
  • Dockerfile - A Yaml file that creates the docker image.
  • prepare-conf - The server that stores the connection settings.
  • swiagent-daemon-set.yaml - The daemon set yaml file.
    This file can be stored in a different location.
Agent installation prerequisites
Before you install the node-level agent in a Kubernetes cluster, perform the following procedures:
  1. Install the Kubernetes Kubectl command line tool on the targeted system.
    See the Kubernetes documentation located at https://kubernetes.io/docs/home for instructions.
  2. Install docker on the targeted system.
    See the docker docs website located at https://docs.docker.com for instructions.
  3. Prepare the SEM agent installer.
  4. Create a new connector profile in the SEM Console. After the node-level agent is deployed, the agent will be added to the connector profile.
About the config setting script
The config setting script changes the spop.conf file on the running pod during the spool up process. This script executes when the pods spool up.
In the following procedures, prepare-conf.sh will be the name of the config setting script.
#!/bin/bash
cat > /usr/local/contego/ContegoSPOP/spop.conf << EOL
ManagerAddress=${SEM_MANAGER_IP_ADDRESS}
ManagerInstallPort=37890
ManagerSecurePort=37891
NioManagerSecurePort=37892
profile.default=${SEM_PROFILE_NAME}
EOL
The profile.default parameter adds the installed node agent to the pre-prepared connector profile. This value can be inserted as the exact profile name (case sensitive).
Build the docker image
The following snippet provides an example of a docker image.
In this snippet, agent-installer.bin is name of the agent installer. Rename the installer if you have an installer with a different name. Additionally, rename all occurrences in Dockerfile.
If you need to rebuild the docker image with new agent installer, you can use the --no-cache argument during build to build it. Otherwise, docker will use the cache.
FROM debian:12-slim
ADD ./agent-installer.bin /
ADD ./prepare-conf.sh /
ENV SWI_SEM_NO_INSTALL "0"
RUN set -eux; \
apt-get update; \
apt-get install -y; \
chmod 777 /tmp; \
chmod 777 agent-installer.bin; \
chmod 777 prepare-conf.sh;
RUN /bin/bash -c "./agent-installer.bin -i silent"
Build the docker image on a cluster control plane machine
  1. Navigate to the target location hosting Dockerfile.
  2. Build the image using the following command:
    docker build -t swi-sem-agent .
    where swi-sem-agent is the image name. Be sure to include the period ( . ) preceded by one space at the end of the command.
Build the docker image on a non-cluster control plane machine
If you are building the image on a machine that is not the cluster control plane, perform the following steps to migrate the image:
  1. Open a Command Prompt window.
  2. Save the build image to a tar file using the following command:
    docker save -o ./swi-sem-agent.tar swiagent
  3. Copy the tar and yaml files to a machine hosting the docker and kubernetes cluster.
  4. Load the tar file and supdoc option to docker using the following command:
    docker load -i ./swi-sem-agent.tar
  5. Verify that the image was imported to docker using the following command:
    docker images
Troubleshooting
If kubernetes cannot load the image, try running the docker image using the following command:
docker run swiagent:latest
Build the DaemonSet image
The following snippet provides an example of a DaemonSet image.
apiVersion: v1
kind: Namespace
metadata:
labels:
apiVersion: v1
kind: Service
metadata:
spec:
type: NodePort
selector:
app: swi-agent
ports:
- name: install-port
port: 37890
targetPort: 37890
- name: control-port
port: 37891
targetPort: 37891
- name: message-port
port: 37892
targetPort: 37892
apiVersion: apps/v1
kind: DaemonSet
metadata:
namespace: swi
labels:
k8s-app: swi-sem-agent
spec:
selector:
matchLabels:
template:
metadata:
labels:
spec:
tolerations:
- key: node-role.kubernetes.io/control-plane
operator: Exists
effect: NoSchedule
- key: node-role.kubernetes.io/master
operator: Exists
effect: NoSchedule
containers:
- name: swi-sem-agent
image: swi-sem-agent:latest
imagePullPolicy: IfNotPresent
env:
- name: SEM_MANAGER_IP_ADDRESS
value: "ip.ad.dre.ss"
- name: SEM_PROFILE_NAME
value: "profile-name"
args: [/bin/sh, -c, './prepare-conf.sh && /usr/local/contego/ContegoSPOP/SWLEMAgent start && tail -f /usr/local/contego/ContegoSPOP/spoplog.txt']
resources:
limits:
memory: 500Mi
requests:
cpu: 100m
memory: 200Mi
volumeMounts:
- name: var-log
mountPath: /var/log
readOnly: true
terminationGracePeriodSeconds: 30
dnsPolicy: Default
volumes:
- name: var-log
hostPath:
path: /var/log
In this example, the first section creates the service that makes the visible ports available for agent-to-manager communications. The second section creates daemonSet, which spawns the agent container on each kubernetes cluster node.
The following table describes the container settings.
Setting Description
env
Includes two container specifications:
  • SEM_MANAGER_IP_ADDRESS - The SEM Manager IP address that connects to the agent.
  • SEM_PROFILE_NAME - The name of the default connector profile that becomes the agent when the installation is completed. Create this profile on the SEM manager before you deploy the agent.
args
Sets the SEM manager IP address and default profile and starts the agent service.
The first part of the command executes the prepare-conf.sh script that sets the manager IP address and default profile. The second part of the command starts the agent service in the container.
volumeMounts
The mounted volume required by the agent to access and read the log file.
In this example, the agent container is mounted in the /var/log directory of the node.
Deploy DaemonSet to the host machine
  2. Apply DaemonSet to the cluster using the following command:
    kubectl apply -f swi-agent-daemon-set.yaml
    where swi-agent-daemon-set.yaml is the name of the yaml file.
  3. Open the SEM Console.
  4. Verify that:
    • The agent is installed correctly.
      See Verify the SEM Agent connection for more information.
    • The agent was added to the specified connector profile.
      In the SEM Console, locate the agent between the nodes. On the right side, there will be a tag with the name of the profile or added connector.
