Documentation forSecurity Event Manager
Manage the SEM data storage
By default, the SEM database is allowed 230 GB of the 250 GB allocated to the SEM virtual appliance. This partition consists of three data stores:
  • Syslog store
  • Events store
  • Original or raw log data store (optional)
The syslog store consists of all syslog or SNMP log data sent to the SEM VM. SEM reads and processes the data in real time, and then sends it to the event store for long-term storage. SEM stores the original data for 50 days in its original format (in case you need to review it). The data in the syslog store is compressed and rotated daily to maintain a consistent 50-days' worth of data. The amount of data stored here should level off at around the 50-day mark.
The event store (the second store) contains all normalized events generated by the SEM Manager and SEM Agents. Data in this store is compressed at ratios of 40:1 to 60:1, which equates to an average compression rate of 95–98%.
The original log store (the third store) is an optional store for original or raw log messages. The data in this store can come from SEM agents or other devices logging to the SEM appliance. You can configure if data is sent to this store at the connector level, so not all devices have to store raw log messages in this manner.
Managing your SEM data storage
Depending on your environment requirements, you can use one or more of the following alternate storage methods:
  • Back up the SEM VM on a regular basis. This will provide offline storage for your SEM data stores.
  • Decrease the number of days that RAW syslog and SNMP data is stored in the Syslog store. This does not include parsed data in the Events store.
  • Deploy another SEM VM to be used as a syslog server.
  • Deploy another SEM VM to be used as a database server.
  • Increase the space allocated to your SEM VM.
For assistance with any of these methods, submit a ticket to Customer Support.
View the SEM database usage numbers
To locate metrics that indicate how the SEM database is used in your deployment, see the following resources:
  • Disk Usage summary in the CMC
  • Database maintenance report
  • Log storage maintenance report
View the Disk usage summary
When you use the command line to log in to SEM, SEM automatically generates a disk usage summary. You can also generate an ad hoc disk usage summary by running the diskusage command from the cmc >appliance prompt. The two lines to note here are Logs/Data and Logs.
  • The Logs/Data figure represents the total space being utilized by the SEM database. This value is presented in the percent % (usedG/allocatedG) format, where percent is the percent of the allocated space currently being used, and allocated is the total amount of space currently allocated to the SEM database.
  • The Logs figure represents the amount of space used by the syslog store. This figure is included in the used figure noted above. To figure out how much space is currently being used by the Event store, subtract the Logs value from the used value. If you are storing original log messages in the SEM database, the above calculation shows the combined space utilized by both your Event and original log stores.
View the Database maintenance report
To view a snapshot of your current database usage, run the Database Maintenance Report in SEM reports. The report includes the following values:
Value Description
Disk Usage Summary Provides disk usage values in terms of the percentage of space allocated to the SEM database.
Disk Usage Details Provides disk usage values in terms of physical file size.
Database Time Span (days) Displays how many days worth of live event data is currently stored in the SEM database.
Other Files Represents the amount of space used by the syslog store.
For more information, see Use the SEM Database Maintenance Report to see retention and volume of traffic located in the Customer Success Center.
View the Log storage maintenance report
Run the log storage maintenance report in SEM reports to obtain detailed information about the original log store. If you have not enabled SEM to store original log messages, this report will be blank.
For more information, see Live Data Storage Retention in SEM located in the Customer Success Center.
Create a disk usage alert
You can create a disk usage alert from the CMC command line to warn you when a disk partition reaches a preselected use limit. When the limit is reached, an InternalWarning event displays in the Monitor view.
You can define the disk use limit by the percentage of unavailable disk space (such as 75 percent), or by the amount of free disk space (such as 58G).
  1. Open the CMC command line.
    See Log in to the SEM CMC command line interface for directions.
  2. To access the Appliance menu, at the cmc> prompt, enter:
    appliance
  3. To view the disk use of each partition, at the cmc::appliance> prompt, enter:
    diskusage
    For example:
    cmc::appliance > diskusage
    Checking Disk Usage (this could take a moment)
    ... ....00.00.00.00.00.00.00.
    Partition Disk Usage:
    SEM:             35% (991M/3.0G)
    OS:              45% (1.3G/3.0G)
    Logs/Data:        1% (901M/234G)
    Temp:             2% (252M/5.9G)
    Database Queue(s): 4.0K (No alerts queued, 0 alerts waiting in memory)
    Rules Queue: 2.1M (0 alerts queued, 0 alerts waiting in memory)
    Console Queue: 2.1M (0 alerts queued, 0 alerts waiting in memory)
    DataCenter Queue: 2.1M (0 alerts queued, unknown number of alerts waiting in memory)
    EPIC Rules Queue: 2.1M (0 alerts queued, 0 alerts waiting in memory)
    Forensic Database Queue: 2.1M (0 data queued, unknown number of data items waiting in memory)
    Logs: 1.3M
    Tool Profiles Message Queue: 2.1M (0 alerts queued, unknown number of alerts waiting in memory)
    cmc::appliance >
  4. At the cmc::appliance> prompt, enter:
    diskusageconfig.
    Each partition and corresponding disk use limit displays on your screen. For example:
    cmc::appliance > diskusageconfig
    Current Disk Usage Configuration:
    # | Partition (filesystem) | Configured limit
    1 |    SEM (/usr/local)    |        90%
    2 |    OS (/)              |        90%
    3 |    Logs/Data (/var/)   |        10G
    4 |    Temp (/tmp)         |        90%
    You can define your disk use limit by the percentage of unavailable disk
    space (such as 75%) or the amount of free disk space (such as 58G).
    Enter the partition number you want to change (enter 'exit' and press
    <Enter> to quit):
  5. Enter the partition number you want to change, and then press Enter.
  6. Enter the disk usage limit value in percentage (such as 75 percent) or size (such as 58G), and then press Enter.
    For example, to change the OS disk partition limit in step 3 from 45 percent to 4 percent, enter 40 percent. To change the OS disk partition limit from 1.3 GB to 2.0 GB, enter 2GB.
    Disk usage limit [90%, sizeK, sizeM, sizeG, sizeT] (default 90%): 40%
    Limit '40%' for the 'OS' partition is set.
    Press <Enter> to set the next partition. Enter 'exit' and press <Enter>
    to quit.
  7. Press Enter to set the next partition and repeat step 6 (if required).
    See Change the Logs/Data partition for additional information.
  8. When you are finished, type exit, and then press Enter to quit.
Change the Logs/Data partition setting
When you set the Logs/Data partition (3), a message prompts you to consider changing the database disk configuration using the dbdiskconfig command. SolarWinds recommends setting the Logs/Data partition and the database disk configuration to the same value.
Change the database disk configuration
  1. Finish configuring your partitions.
  2. At the cmc::appliance> prompt, enter:
    dbdiskconfig
    The following message displays:
    Current configuration:
    DoNotExceedPercentage = 90%
    The Manager will restart and apply your changes. To exit, enter 'exit' and press Enter.
    Enter a new value for DoNotExceedPercentage (default 90):
    Please enter an inter number 0-100 or 'exit'
  3. At the prompt, enter a usage limit value between 0 and 100, and then press Enter.
    If you enter a value less than 25, the partition will be deleted when this value is reached.
    The database disk configuration value is saved, and the appliance restarts the Manager Service.
