Enable Dark Mode
Dark Mode changes the SEM web console display to a light-on-dark color scheme. This color scheme helps reduce eye strain and glare in dark environments and improve readability in bright environments.
You can enable or disable Dark Mode from the menu bar or the Settings menu.
Enable and disable from the menu bar
Log in to SEM.
In the menu bar, click your user name (for example, Admin).
In the drop-down menu, click the Dark Mode toggle to switch between enabled...
...and disabled.
Enable and disable from the Settings menu
Log in to SEM.
In the menu bar, click the Settings icon.
In the Settings screen, select User Preferences.
In the User Preferences screen, click the Dark Mode toggle to switch between enabled...
...and disabled.
