Configure the Kube API reader connection settings
To connect to the Kubernetes API, provide the connection and authentication properties to the reader. There are different approaches available, which are explained in this section.
The following matrix provides an overview of the methods that work for each corresponding agent/manager deployment.
Deployment vs connection method support
| Connector configuration | Auto configuration | Local Proxy | Service Account |
SEM agent is managed by Kubernetes. The agent is deployed as a pod, similar to being part of the Daemon Set |
Yes | No | Yes |
SEM agent is not managed by Kubernetes. The agent is installed with |
Requires one of the following methods:
$HOME is the home of a user running the agent process--in this case, /root. |
Yes Requires running |
Yes |
SEM agent is installed outside of the Kubernetes cluster/nodes. The Kubernetes API is remotely accessible for this machine (similar to the remote |
$HOME is the home of a user running the agent process. |
Yes |
| Manager outside of the Kubernetes cluster. The Kubernetes API is remotely accessible to the manager. | No | No | Yes |
Agent inside the cluster
You can implement this connection using one of the following methods:
Auto-configuration
Using the auto-configuration method, you are not required to specify any additional connection parameters because they can be auto-discovered.
Auto-configuration uses the settings from different sources on the machine in the following order of priority:
System properties or environment variables (useful to override config).
Kube config file.
By default, this file is located on the FS at
~/.kube/config. Resources including certificates, urls, and so on are configured based on the file contents. -
Service account token and mounted CA certificate (located on the FS).
The following rules apply:
If the agent is running from a Pod environment, additional settings are not required. Kubernetes will set all resources to their proper locations.
By default, the token file is expected at
/var/run/secrets/kubernetes.io/serviceaccount/token
By default, the CA certificate is expected at
/var/run/secrets/kubernetes.io/serviceaccount/ca.crt -
The host and port must be set as
envvariables unless the API is accessible throughkubernetes.default.svc.Optionally, you can set
KUBERNETES_MASTERas a whole master URL. See the table with all properties.-
KUBERNETES_SERVICE_HOST(without https) -
KUBERNETES_SERVICE_PORT(can be left unset and will default to 443)
Overridable auto-configuration properties
You can define or override the env/system properties on the machine hosting the SEM agent to enable auto-configuration or adjust its behavior.
| Property / Env variable | Description | Default value |
kubernetes.master / |
Kubernetes master URL | https://kubernetes.default.svc
API version | v1
kubernetes.trust.certificates /
Trust all certificates | false
kubernetes.disable.hostname.verification /
false
kubernetes.certs.ca.file /
kubernetes.certs.ca.data /
kubernetes.certs.client.file /
kubernetes.certs.client.data /
kubernetes.certs.client.key.file /
kubernetes.certs.client.key.data /
kubernetes.certs.client.key.algo /
Client key encryption algorithm | RSA
kubernetes.certs.client.key.passphrase / KUBERNETES_CERTS_CLIENT_KEY_PASSPHRASE
kubernetes.auth.serviceAccount.token / KUBERNETES_AUTH_SERVICEACCOUNT_TOKEN
Name of the service account token file | /var/run/secrets/kubernetes.io/
kubernetes.auth.tryKubeConfig /
Configure client using Kubernetes config | true |
kubeconfig / KUBECONFIG
Name of the Kubernetes config file to read | ~/.kube/config
kubernetes.auth.tryServiceAccount /
Configure client from the Service account | true
kubernetes.tryNamespacePath /
Configure client namespace from Kubernetes service account namespace path | true
kubernetes.auth.token /
Master URL host (used when configuring for SA) where the Kubernetes API is reachable | kubernetes.default.svc
Master URL port (used when configuring for SA) where Kubernetes API is reachable |
Override env variables for the Linux agent service
SEM runs the Linux agent as a systemd service. Exporting system properties through the current bash shell will not work. Instead, use the systemd service drop-in.
The solution is to use the standalone environment file that is loaded by means of EnvironmentFile. This approach is more secure and prevents the values from being shown by means of the systemctl show service. Additionally, this approach is cleaner if you need to define multiple variables.
mkdir -p /etc/swlem-agent
# create your environmental file in a proper location"
# put all of your variables on a separate line, like this:
# MY_SECRET=mypassword
nano /etc/swlem-agent/swlem-agent.conf
# create the drop-in dir
sudo mkdir -p /etc/systemd/system/swlem-agent.service.d
# create the drop-in with EnvironmentFile override
{ echo "[Service]";
echo "EnvironmentFile=/etc/swlem-agent/swlem-agent.conf";
} | tee /etc/systemd/system/swlem-agent.service.d/override.conf
# reload unit files
systemctl daemon-reload
# restart the agent service for new options to take effect
systemctl restart swlem-agent.service
Afterwards, you can modify the variables in the /etc/swlem-agent/swlem-agent.conf file and then restart the agent service for them to take effect.
Another solution is to pass properties directly by means of Environment if the standalone env file should be omitted:
# create the drop-in with kube config location override
{ echo "[Service]";
echo "Environment=\"KUBECONFIG=/home/kube/.kube/config\"";
# reload unit files
However, this approach is not as flexible as the first approach.
Local proxy (localhost only)
The kubectl proxy command creates a proxy server (or an application-level gateway) between localhost and the Kubernetes API server. The kubectl proxy offloads the mutual client-server authentication responsibility from the caller. Since the communication between the caller and the proxy occurs over the localhost, it is considered secure.
The proxy takes care of the client-server authentication using the information from the current context selected in the kube config file. This approach greatly simplifies API access.
The connector fields include the proxy port [Integer]—the HTTP port where the kubectl proxy is listening.
Agent or manager is outside of the cluster
The following methods require manual connection and authentication inputs to the reader by the user.
Service Account (SA) token authentication
The SA token is issued by Kubernetes and acts a client secret during authentication and authorization. The CA certificate is used to verify the server identity by the client.
The following table lists the connector fields.
| Field | Description | Description |
| Master URL [String] |
The API URL used for the connection |
Can be received with the following command:
| SA token [String] | Service account bearer token |
Can be received with command:
where |
| CA certificate [String] | Base64 encoded contents of the server CA certificate in PEM format |
where |
