CMC main menu
The CMC main menu opens when you log in to the CMC command-line interface.
See About the CMC command line in SEM for information about using the CMC command line.
Top-Level CMC commands
Commands are listed in order of appearance.
| Command | Description |
appliance
Displays the See SEM CMC appliance menu for more information. |
manager
Displays the See SEM CMC manager menu for more information. |
service
Displays the See SEM CMC service menu for more information. |
| rawlogs | Displays the rawlogs menu to run configuration and maintenance commands. |
Installs the SEM upgrade package that you will use to upgrade your SEM VM. This command functions the same as the hotfix command. |
admin
Opens the admin command-line interface in the Lynx text browser. |
import
Imports a keytab file from Active Directory into SEM. This file is required to configure SEM for Active Directory single sign-on. See Set up single sign-on (SSO) in SEM for details. |
help
Displays the Help menu. |
exit
Exits the CMC management console. |
