CMC appliance menu
The cmc::appliance> menu includes commands for managing network and system settings.
See About the CMC command line in SEM for information about using the CMC command line.
Type the appliance command at the main menu to open the cmc::appliance> prompt. Commands available from the appliance menu are listed in the following table in alphabetical order.
Y in the "Restart Required" column indicates that a command requires an automatic restart of the SEM Manager service. See Start and stop the SEM appliance and agent for help.
| Command | Description | Restart Required |
activate |
Configures essential SEM features. Run this command after you install the SEM license. See Run the activate command to secure SEM and configure network settings for instructions. |
N |
checklogs
Shows the contents of the SEM log files from sources such as syslog and SNMP. | N |
clearsyslog
Removes all rotated and compressed local files. | N |
cleantemp
Removes temporary files SEM created during normal operation. Run this command to recover used disk space, or at the suggestion of SolarWinds Support. | N |
dateconfig
Sets/shows the SEM VM's date and time. |
N |
dbdiskconfig
Configures the database retention setting (that is, the percentage of free space for the database). This command requires an automatic restart of the SEM Manager service. | Y |
diskusage
Checks disk usage consumed by the SEM Manager and several other internal components (such as the database or log files), and provides a summary. This information is included when you send SolarWinds Support information using the support command. |
N |
diskusageconfig
Sets the SEM Manager disk usage limit by the percentage of unavailable disk space or the amount of free disk space. | N |
editbanner
Edits the SSH login banner. | N |
exit
Exits the appliance menu and returns to the main menu. |
N |
exportsyslog
Exports the system logs. | N |
hostname
Changes the hostname of the SEM VM. | N |
import
Imports the SIM or SEM backup to the SEM. | N |
limitsyslog
Interrogates and/or changes the number of rotated log files to be kept. | N |
Enables or disables the multimanager. If you enable multimanager, some security scanners may generate cross-domain security warnings about SEM. If this feature is not required, keep it disabled. |
N |
setlogrotate
Sets the syslog rotation frequency to either hourly or daily. | N |
netconfig
Configures network settings for the SEM VM, such as the IP address, subnet mask, and DNS server(s). | N |
ntpconfig
Configures the Network Time Protocol (NTP) service on the SEM VM for synchronization with a time server. | N |
password
Changes the CMC user password. | N |
ping
Pings other IP addresses or host names from the SEM VM to verify network connectivity. | N |
reboot
Reboots the SEM VM. | N |
shutdown
Shuts down the SEM VM. | N |
top
Displays and monitors CPU and memory usage, as well as per process information for the Manager Network Appliance. | N |
tzconfig
Configure the SEM VM time zone information. | N |
viewnetconfig
Displays the SEM VM network settings, such as the IP address, subnet mask, and DNS server(s). | N |
exit
N |
