Determine the SEM upgrade path
If you are running a SEM End of Life or End of Engineering version, you can update to the latest version by following the designated upgrade path for your version.
About the upgrade installers
Use the following installers to upgrade your deployment:
Security Event Manager - Recovery Boot CD
SEM Upgrade ISO
These installers are located on the SolarWinds Customer Portal.
The Security Event Manager - Recovery Boot CD installer provides the necessary files to support older versions in the upgrade path. If you are running an End of Life or End of Engineering version, run the CD where indicated between each version in the upgrade path.
The SEM Upgrade ISO installer upgrades your deployment with a version you select and download in the Customer Portal. Based on the upgrade path, you may be required to download several versions of the SEM Upgrade ISO installer from the Customer Portal to upgrade your deployment to the latest release.
Download the upgrade installers
Log in to the SolarWinds Customer Portal.
Click Downloads > Download Product.
Click the Products drop-down menu and select:
Security Event Manager (SEM), formerly Log and Event Manager (LEM) -
Click the Licenses drop-down menu and select your license tier.
Locate your current version listed in Currently supported versions or End of Life versions.
Under Upgrade path, record the installers that are required to upgrade your deployment to the latest release.
Download the SEM Upgrade ISO installer for your upgrade version.
For example, if you need to upgrade to version 2023.4.1 in the upgrade path, click the drop-down menu, select 2023.4.1, and download this installer.
Repeat step 8 for each additional installer required in the upgrade path, including the installer for the latest release.
Example upgrade procedure
When you upgrade your SEM components from an existing version listed in the Supported upgrade paths table to the latest version, be sure to:
Create a snapshot of each deployment in the upgrade path
Ensure that:
You can connect to the SEM Console.
Your SEM deployment is functioning properly.
All SEM Windows agents are upgraded, connected, and sending logs and events to the SEM Manager.
If you encounter issues during the upgrade, you can use a snapshot to revert to a previous version, fix any issues, and repeat the upgrade procedure.
The following procedure provides an example of how to upgrade your SEM components from an existing version to the latest version in the upgrade path.
Ensure that you have a snapshot of your existing deployment.
In the supported upgrade paths table, locate the SEM version that is currently running in your deployment.
Run the SEM Upgrade ISO for the first SEM version listed in the upgrade path.
When the installation is completed, ensure that:
Take a snapshot of your upgraded deployment.
Repeat step 3 through step 5 for each remaining SEM ISO listed in the upgrade path.
The following table provides the upgrade paths from previous LEM and SEM versions to the latest SEM version.
| SEM/LEM version | Upgrade path |
| 6.0* | Recovery Boot CD > 6.0.1 > Recovery Boot CD > 6.2.1 > Recovery Boot CD > 6.3.1 > Recovery Boot CD > 6.4 > Recovery Boot CD > 2020.2 > 2022.2 > 2022.4 >2022.4.1 > 2023.2 > 2024.2 > 2024.4 > latest version |
6.0.1* 6.1* |
Recovery Boot CD > 6.2.x > Recovery Boot CD > 6.3.1 > Recovery Boot CD > 6.4 > Recovery Boot CD > 2020.2.2 > Recovery Boot CD > 2022.4 > 2022.4.1 > 2023.2 > 2024.2 > 2024.4 > latest version |
6.2x* 6.3.0 |
| 6.3.1* | Recovery Boot CD > 6.4 > Recovery Boot CD > 2020.2.2 > Recovery Boot CD > 2022.4 > 2022.4.1 > 2023.2 > 2024.2 > 2024.4 > latest version |
6.4 6.5 6.6 6.7 6.7.1 6.7.2 |
2019.4 2020.2 2020.2.1 |
Recovery Boot CD > 2021.2.1 > Recovery Boot CD > 2022.4 > 2022.4.1 > 2023.2 > 2024.2 > 2024.4 > latest version |
2020.2.2 2020.4 2020.4.1 |
2021.2 2021.2.1 2021.4 |
2022.2 2022.2.1 2022.2.2 |
| 2022.4.1 > 2023.2 > 2024.2 > 2024.4 latest version | |
| 2022.4.1 | 2023.2 > 2024.2 > 2024.4 > latest version |
2023.2 2023.2.1 2023.4 2023.4.1 |
2024.2 2024.2.1 |
| 2024.4 and later | latest version |
| 2025.4 | latest version |
| 2026.2 | latest version |
| 2026.4 | latest version |
* If SMB1 is disabled during the upgrade process, upgrade to 6.3.1 hotfix 7 to perform an ISO upgrade before moving to version 6.4.
