Documentation forAppOptics
AppOptics will reach its End of Service Life on January 31, 2026. Migrate to the next generation APM solution as soon as possible to avoid disruption. See FAQ, or contact appopticsng-questions@solarwinds.com for support. Documentation is no longer being updated, and some features or links may not work as described.
Azure Key Vault
Azure Key Vault can be used to Securely store and tightly control access to tokens, passwords, certificates, API keys, and other secrets.
Configuration
On the Azure integration page, ensure that the Azure Key Vault service is selected for metric collection.
Metrics
Name Description Tags
azure.key_vault.service_api.hit Number of total service api hits ActivityType, ActivityName, Region, Name, Subscription
azure.key_vault.service_api.latency Overall latency of service api requests ActivityType, ActivityName, StatusCode, Region, Name, Subscription
azure.key_vault.service_api.result Number of total service api results ActivityType, ActivityName, StatusCode, Region, Name, Subscription
Navigation Notice: When the APM Integrated Experience is enabled, AppOptics shares a common navigation and enhanced feature set with other integrated experience products. How you navigate AppOptics and access its features may vary from these instructions.
