Documentation forAppOptics
AppOptics will reach its End of Service Life on January 31, 2026. Migrate to the next generation APM solution as soon as possible to avoid disruption. See FAQ, or contact appopticsng-questions@solarwinds.com for support. Documentation is no longer being updated, and some features or links may not work as described.
Function: scale(set[], options)
Given an arbitrary number of series, returns a set of equal length where each value has been multiplied by the transform factor in the options map. The one supported option is:
  • factor - Number by which to multiply every value in the input series by. This value can be represented as a float value, eg. "0.1", "1.34", "1024", etc. or as a simple fraction: "1/1024" (regex: `\d+/\d+`). The second format is provided as a convenience method so that common transforms (bytes->kilobytes) can be done without having to calculate the fractional float values.
scale(s("AppOptics.memory.memory.used", {"@host":"*"}), {factor:"1/1048576"})
Navigation Notice: When the APM Integrated Experience is enabled, AppOptics shares a common navigation and enhanced feature set with other integrated experience products. How you navigate AppOptics and access its features may vary from these instructions.
