Documentation forAppOptics
AppOptics will reach its End of Service Life on January 31, 2026. Migrate to the next generation APM solution as soon as possible to avoid disruption. See FAQ, or contact appopticsng-questions@solarwinds.com for support. Documentation is no longer being updated, and some features or links may not work as described.
Function: subtract(set[2])
Takes a set of precisely 2 series. Uses the first (set[0]) as the minuend and the second (set[1]) as the subtrahend to generate a difference series (i.e. set[0] - set[1]) as the return value.
subtract([
      sum(s("foo",{"@host": "prod.web*"})),
      sum(s("bar",{"@host": "prod.web*"}))
Navigation Notice: When the APM Integrated Experience is enabled, AppOptics shares a common navigation and enhanced feature set with other integrated experience products. How you navigate AppOptics and access its features may vary from these instructions.
