Documentation forAppOptics
AppOptics will reach its End of Service Life on January 31, 2026. Migrate to the next generation APM solution as soon as possible to avoid disruption. See FAQ, or contact appopticsng-questions@solarwinds.com for support. Documentation is no longer being updated, and some features or links may not work as described.
Function: rate(set[], options = {})
Given an arbitrary number of series, returns a set of equal length where each value has been converted to a rate over the defined duration. The duration of the period can be set with the following parameter:
  • duration - This converts every value to a rate, where the period of the rate is defined by the given duration. For every value x, the effective transform run is: (x/p) * duration. Where p is the automatic period of the data determined by the current rollup resolution, the saved metric period attribute, or the downsample period specified in a call to series(). For example, to get "rate per minute", you would set duration to "60" ( x/p * 60 ). Whereas, to get "rate per second", you would set duration to "1" ( x/p * 1). The duration defaults to "1" if not specified, implying all rates are converted to per-second.
rate(s("http.requests.count", {"@host":"*"}, {period: "300"}),{duration:"60"})
How rate() detects the period
  • If a metric does not have a period set, then period is defaulted to resolution of the data.
  • If the series() was given a ‘period' parameter, it will be used in place of the metric period.
  • When you switch to a higher viewing window, the data switches to a rollup resolution. Therefore, the period is calculated as the Max of (period, rollup resolution).
Navigation Notice: When the APM Integrated Experience is enabled, AppOptics shares a common navigation and enhanced feature set with other integrated experience products. How you navigate AppOptics and access its features may vary from these instructions.
