Documentation forAppOptics
AppOptics will reach its End of Service Life on January 31, 2026. Migrate to the next generation APM solution as soon as possible to avoid disruption. See FAQ, or contact appopticsng-questions@solarwinds.com for support. Documentation is no longer being updated, and some features or links may not work as described.
Azure Monitor
Connect Azure Metrics
Connecting AppOptics to Azure Metrics takes a few easy steps. First go to the integrations page and select the Azure Integration card.
azure_card
Click the ‘Add Configuration' button and follow the form to authenticate with Microsoft. The permissions will need to be accepted for AppOptics to begin ingesting metrics.
Once the integration is saved, it can take up to 10 minutes to start seeing metrics in our system.
Once the process is completed, clicking on the name will bring up the service listing where the services from which AppOptics pulls metrics from can be controlled. By default, all services are selected.
azure_edit_service
Supported Services
Navigation Notice: When the APM Integrated Experience is enabled, AppOptics shares a common navigation and enhanced feature set with other integrated experience products. How you navigate AppOptics and access its features may vary from these instructions.
