Documentation forAppOptics
AppOptics will reach its End of Service Life on January 31, 2026. Migrate to the next generation APM solution as soon as possible to avoid disruption. See FAQ, or contact appopticsng-questions@solarwinds.com for support. Documentation is no longer being updated, and some features or links may not work as described.
Function: zero_fill(set[])
Given a sparse metric stream, zero_fill() will "fill in" any missing data points with a value of 0. This function is an alias to fill, with the value parameter set to 0.
zero_fill(s("AWS.ELB.HTTPCode_Backend_5XX", {"name": "*"}, {period: "60"}))
In order for zero_fill() to work, the metric must have its period attribute set, or you must supply period to the series function.
Example:
In the graph below, the metric has multiple streams which report intermittently:
composite-metric-no-fill
If we were to divide this metric with another metric we would need to ensure both metrics report at a consistent interval. Let's use the fill function to ensure a 0 value is rendered every 5 minutes (300 seconds) if no data is received:
zero_fill(s("json.errors.count", {"@host": "*"}, {period: "300"}))
All streams now display a 0 value if no measurements are received.
composite-metric-fill
Navigation Notice: When the APM Integrated Experience is enabled, AppOptics shares a common navigation and enhanced feature set with other integrated experience products. How you navigate AppOptics and access its features may vary from these instructions.
